[PATCH 2/2] rtemstoolkit: msys2 compatibility
Fri Jan 8 08:56:19 UTC 2016
On 8/01/2016 7:49 PM, Sebastian Huber wrote:
> On 08/01/16 09:45, Chris Johns wrote:
>> On 8/01/2016 7:41 PM, Sebastian Huber wrote:
>>> >It seems that Python (python.org and msys2) on Windows has no implict
>>> >current directory import path. We used exactly this approach for the
>>> >rtems_waf module previously.
>> Then I suggest this is added. Check the command wrappers and add '.' to
>> the system path, eg rtems-tester.
> There is still the cyclic git.py <-> options.py dependency.
With the change I suggested, your change or both?
