[PATCH 2/2] rtemstoolkit: msys2 compatibility
Fri Jan 8 09:05:41 UTC 2016
On 08/01/16 09:56, Chris Johns wrote:
> On 8/01/2016 7:49 PM, Sebastian Huber wrote:
>> >On 08/01/16 09:45, Chris Johns wrote:
>>> >>On 8/01/2016 7:41 PM, Sebastian Huber wrote:
>>>>> >>> >It seems that Python (python.org and msys2) on Windows has no implict
>>>>> >>> >current directory import path. We used exactly this approach for the
>>>>> >>> >rtems_waf module previously.
>>> >>Then I suggest this is added. Check the command wrappers and add '.' to
>>> >>the system path, eg rtems-tester.
>> >There is still the cyclic git.py <-> options.py dependency.
> With the change I suggested, your change or both?
I am not sure what you mean with "Check the command wrappers and add '.'
tothe system path, eg rtems-tester.".
The cyclic dependency is there in all versions.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
