[PATCH 2/2] rtemstoolkit: msys2 compatibility
Mon Jan 11 01:03:33 UTC 2016
On 08/01/2016 20:05, Sebastian Huber wrote:
> I am not sure what you mean with "Check the command wrappers and add '.'
> tothe system path, eg rtems-tester.".
The command wrapper is:
  https://git.rtems.org/rtems-tools/tree/tester/rtems-test
and does adding '.' fix the problem? I am not sure if this a suitable or
questionable fix.
> The cyclic dependency is there in all versions.
I will need to see this and understand the issue. An imported module
should be ok to import again and again.
