[PATCH] Clearly mark SMP support as experimental in 4.11
Sebastian Huber
Mon Jan 11 07:30:00 UTC 2016
aclocal/enable-smp.m4 | 10 +++++++---
c/src/aclocal/enable-smp.m4 | 10 +++++++---
cpukit/aclocal/enable-smp.m4 | 10 +++++++---
doc/user/smp.t | 10 +++++-----
4 files changed, 26 insertions(+), 14 deletions(-)
diff --git a/aclocal/enable-smp.m4 b/aclocal/enable-smp.m4
index 590a7b1..52605c7 100644
--- a/aclocal/enable-smp.m4
+++ b/aclocal/enable-smp.m4
@@ -2,8 +2,8 @@ AC_DEFUN([RTEMS_ENABLE_SMP],
## AC_BEFORE([$0], [RTEMS_CHECK_SMP])dnl
-AC_ARG_ENABLE(smp,
-[AS_HELP_STRING([--enable-smp],[enable support for symmetric multiprocessing
+AC_ARG_ENABLE(experimental-smp,
+[AS_HELP_STRING([--enable-experimental-smp],[enable experimental support for symmetric multiprocessing
(SMP)])],
[case "${enableval}" in
yes) case "${RTEMS_CPU}" in
@@ -13,5 +13,9 @@ AC_ARG_ENABLE(smp,
no) RTEMS_HAS_SMP=no ;;
*) AC_MSG_ERROR(bad value ${enableval} for enable-smp option) ;;
-esac],[RTEMS_HAS_SMP=no])
+esac],[RTEMS_HAS_SMP=no])
+AC_ARG_ENABLE(smp,
+[AC_MSG_ERROR([SMP support is experimental in RTEMS 4.11, use --enable-experimental-smp])],
diff --git a/c/src/aclocal/enable-smp.m4 b/c/src/aclocal/enable-smp.m4
--- a/c/src/aclocal/enable-smp.m4
+++ b/c/src/aclocal/enable-smp.m4
-AC_ARG_ENABLE(smp,
(SMP)])],
+AC_ARG_ENABLE(smp,
diff --git a/cpukit/aclocal/enable-smp.m4 b/cpukit/aclocal/enable-smp.m4
--- a/cpukit/aclocal/enable-smp.m4
+++ b/cpukit/aclocal/enable-smp.m4
-AC_ARG_ENABLE(smp,
(SMP)])],
+AC_ARG_ENABLE(smp,
diff --git a/doc/user/smp.t b/doc/user/smp.t
index e5fdf58..3cac740 100644
--- a/doc/user/smp.t
+++ b/doc/user/smp.t
@@ -17,11 +17,11 @@ available on
@item SPARC.
@end itemize
-It must be explicitly enabled via the @code{--enable-smp} configure command
-line option. To enable SMP in the application configuration see
- at ref{Configuring a System Enable SMP Support for Applications}. The default
-scheduler for SMP applications supports up to 32 processors and is a global
-fixed priority scheduler, see also @ref{Configuring a System Configuring
+It must be explicitly enabled via the @code{--enable-experimental-smp}
+configure command line option. To enable SMP in the application configuration
+see @ref{Configuring a System Enable SMP Support for Applications}. The
+default scheduler for SMP applications supports up to 32 processors and is a
+global fixed priority scheduler, see also @ref{Configuring a System Configuring
Clustered/Partitioned Schedulers}. For example applications see
@file{testsuites/smptests}.
1.8.4.5
