[PATCH 17/38] Optional POSIX Signals initialization
Tue Jan 26 15:37:43 UTC 2016
Update #2408.
 cpukit/posix/include/rtems/posix/psignalimpl.h |  5 ----
 cpukit/posix/src/psignal.c                     |  9 ++++++-
 cpukit/sapi/src/posixapi.c                     |  1 -
 cpukit/score/include/rtems/sysinit.h           |  1 +
 testsuites/sptests/spsysinit01/init.c          | 36 ++++++++++++++++++++++++++
 5 files changed, 45 insertions(+), 7 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/psignalimpl.h b/cpukit/posix/include/rtems/posix/psignalimpl.h
index d7e1afa..b887084 100644
--- a/cpukit/posix/include/rtems/posix/psignalimpl.h
+++ b/cpukit/posix/include/rtems/posix/psignalimpl.h
@@ -72,11 +72,6 @@ extern Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
  *  Internal routines
- * @brief POSIX signals manager initialization.
-void _POSIX_signals_Manager_Initialization(void);
 #define _POSIX_signals_Acquire( lock_context ) \
   _Thread_queue_Acquire( &_POSIX_signals_Wait_queue, lock_context )
diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
index f00bcdb..08b049b 100644
--- a/cpukit/posix/src/psignal.c
+++ b/cpukit/posix/src/psignal.c
@@ -33,6 +33,7 @@
 #include <rtems/config.h>
 #include <rtems/seterr.h>
+#include <rtems/sysinit.h>
  *  Ensure we have the same number of vectors and default vector entries
@@ -166,7 +167,7 @@ void _POSIX_signals_Action_handler(
   executing->Wait.return_code = hold_errno;
+static void _POSIX_signals_Manager_Initialization(void)
   uint32_t   signo;
   uint32_t   maximum_queued_signals;
@@ -213,3 +214,9 @@ void _POSIX_signals_Manager_Initialization(void)
     _Chain_Initialize_empty( &_POSIX_signals_Inactive_siginfo );
+RTEMS_SYSINIT_ITEM(
+  _POSIX_signals_Manager_Initialization,
+  RTEMS_SYSINIT_POSIX_SIGNALS,
+  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index 60fa17e..1c54b77 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -64,7 +64,6 @@ void _POSIX_API_Initialize(void)
   _POSIX_Key_Manager_initialization();
   #ifdef RTEMS_POSIX_API
-    _POSIX_signals_Manager_Initialization();
     _POSIX_Threads_Manager_initialization();
     _POSIX_Condition_variables_Manager_initialization();
     _POSIX_Mutex_Manager_initialization();
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index faef223..a6cb32f 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -42,6 +42,7 @@ extern "C" {
 #define RTEMS_SYSINIT_CLASSIC_DUAL_PORTED_MEMORY 000348
 #define RTEMS_SYSINIT_CLASSIC_RATE_MONOTONIC     000349
 #define RTEMS_SYSINIT_CLASSIC_BARRIER            00034a
+#define RTEMS_SYSINIT_POSIX_SIGNALS              000360
 #define RTEMS_SYSINIT_IDLE_THREADS               000380
 #define RTEMS_SYSINIT_BSP_LIBC                   000400
 #define RTEMS_SYSINIT_BEFORE_DRIVERS             000500
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index 31e691e..328851d 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -17,6 +17,7 @@
 #endif
 #include <assert.h>
+#include <string.h>
@@ -25,6 +26,9 @@
 #include <rtems/test.h>
 #include <rtems/extensionimpl.h>
+#ifdef RTEMS_POSIX_API
+#include <rtems/posix/psignalimpl.h>
+#endif /* RTEMS_POSIX_API */
 #include <rtems/rtems/barrierimpl.h>
 #include <rtems/rtems/dpmemimpl.h>
 #include <rtems/rtems/messageimpl.h>
@@ -74,6 +78,10 @@ typedef enum {
   CLASSIC_RATE_MONOTONIC_POST,
   CLASSIC_BARRIER_PRE,
   CLASSIC_BARRIER_POST,
+  POSIX_SIGNALS_PRE,
+  POSIX_SIGNALS_POST,
   IDLE_THREADS_PRE,
   IDLE_THREADS_POST,
   BSP_LIBC_PRE,
@@ -309,6 +317,34 @@ LAST(RTEMS_SYSINIT_CLASSIC_BARRIER)
   next_step(CLASSIC_BARRIER_POST);
+FIRST(RTEMS_SYSINIT_POSIX_SIGNALS)
+  assert(
+    memcmp(
+      &_POSIX_signals_Vectors,
+      _POSIX_signals_Default_vectors,
+      sizeof(_POSIX_signals_Vectors)
+    ) != 0
+  next_step(POSIX_SIGNALS_PRE);
+LAST(RTEMS_SYSINIT_POSIX_SIGNALS)
+  assert(
+    memcmp(
+    ) == 0
+  next_step(POSIX_SIGNALS_POST);
 FIRST(RTEMS_SYSINIT_IDLE_THREADS)
   assert(_System_state_Is_before_initialization(_System_state_Get()));
1.8.4.5
