[PATCH 18/38] Optional POSIX Threads initialization
Tue Jan 26 15:37:44 UTC 2016
Update #2408.
 cpukit/posix/include/rtems/posix/pthreadimpl.h |  9 +--------
 cpukit/posix/src/killinfo.c                    | 12 ++----------
 cpukit/posix/src/pthread.c                     | 11 ++++++++++-
 cpukit/sapi/src/posixapi.c                     |  2 --
 cpukit/score/include/rtems/sysinit.h           |  1 +
 testsuites/sptests/spsysinit01/init.c          | 21 +++++++++++++++++++++
 6 files changed, 35 insertions(+), 21 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index f95ac9c..9aff71c 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -44,7 +44,7 @@ extern "C" {
  * The following defines the information control block used to manage
  * this class of objects.
-POSIX_EXTERN Thread_Information  _POSIX_Threads_Information;
+extern Thread_Information _POSIX_Threads_Information;
  * This variable contains the default POSIX Thread attributes.
@@ -61,13 +61,6 @@ extern pthread_attr_t _POSIX_Threads_Default_attributes;
 extern void (*_POSIX_Threads_Initialize_user_threads_p)(void);
- * @brief POSIX threads manager initialization.
- * This routine performs the initialization necessary for this manager.
-void _POSIX_Threads_Manager_initialization(void);
  * @brief Copy POSIX Thread attribute structure.
  * This routine copies the attr2 thread attribute structure
diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
index 7f4adc7..a29a8e6 100644
--- a/cpukit/posix/src/killinfo.c
+++ b/cpukit/posix/src/killinfo.c
@@ -198,16 +198,8 @@ int killinfo(
       continue;
     the_info = _Objects_Information_table[ the_api ][ 1 ];
-    #if defined(RTEMS_DEBUG)
-       *  This cannot happen in the current (as of June 2009) implementation
-       *  of initialization but at some point, the object information
-       *  structure for a particular manager may not be installed.
-      if ( !the_info )
-        continue;
-    #endif
+    if ( !the_info )
+      continue;
     maximum = the_info->maximum;
     object_table = the_info->local_table;
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index ee7da11..691dfc3 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -26,6 +26,7 @@
 #include <rtems/config.h>
+#include <rtems/sysinit.h>
 #include <rtems/score/apiext.h>
 #include <rtems/score/stack.h>
@@ -43,6 +44,8 @@
 #include <rtems/score/cpusetimpl.h>
+Thread_Information _POSIX_Threads_Information;
  *  The default pthreads attributes structure.
@@ -338,7 +341,7 @@ User_extensions_Control _POSIX_Threads_User_extensions = {
  *  This routine initializes all threads manager related data structures.
+static void _POSIX_Threads_Manager_initialization(void)
   #if defined(RTEMS_SMP) && defined(__RTEMS_HAVE_SYS_CPUSET_H__)
     const CPU_set_Control *affinity;
@@ -381,3 +384,9 @@ void _POSIX_Threads_Manager_initialization(void)
    *       Register the MP Process Packet routine.
+RTEMS_SYSINIT_ITEM(
+  _POSIX_Threads_Manager_initialization,
+  RTEMS_SYSINIT_POSIX_THREADS,
+  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index 1c54b77..4cf5249 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -38,7 +38,6 @@
 #include <rtems/posix/psignalimpl.h>
-#include <rtems/posix/pthreadimpl.h>
 #include <rtems/posix/rwlockimpl.h>
 #include <rtems/posix/timerimpl.h>
 #include <rtems/posix/semaphoreimpl.h>
@@ -64,7 +63,6 @@ void _POSIX_API_Initialize(void)
   _POSIX_Key_Manager_initialization();
   #ifdef RTEMS_POSIX_API
-    _POSIX_Threads_Manager_initialization();
     _POSIX_Condition_variables_Manager_initialization();
     _POSIX_Mutex_Manager_initialization();
     _POSIX_Message_queue_Manager_initialization();
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index a6cb32f..1da3b30 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -43,6 +43,7 @@ extern "C" {
 #define RTEMS_SYSINIT_CLASSIC_RATE_MONOTONIC     000349
 #define RTEMS_SYSINIT_CLASSIC_BARRIER            00034a
 #define RTEMS_SYSINIT_POSIX_SIGNALS              000360
+#define RTEMS_SYSINIT_POSIX_THREADS              000361
 #define RTEMS_SYSINIT_IDLE_THREADS               000380
 #define RTEMS_SYSINIT_BSP_LIBC                   000400
 #define RTEMS_SYSINIT_BEFORE_DRIVERS             000500
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index 328851d..3bbea9c 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -28,6 +28,7 @@
 #include <rtems/extensionimpl.h>
+#include <rtems/posix/pthreadimpl.h>
 #endif /* RTEMS_POSIX_API */
 #include <rtems/rtems/barrierimpl.h>
 #include <rtems/rtems/dpmemimpl.h>
@@ -81,6 +82,8 @@ typedef enum {
   POSIX_SIGNALS_PRE,
   POSIX_SIGNALS_POST,
+  POSIX_THREADS_PRE,
+  POSIX_THREADS_POST,
   IDLE_THREADS_PRE,
   IDLE_THREADS_POST,
@@ -343,6 +346,18 @@ LAST(RTEMS_SYSINIT_POSIX_SIGNALS)
   next_step(POSIX_SIGNALS_POST);
+FIRST(RTEMS_SYSINIT_POSIX_THREADS)
+  assert(_POSIX_Threads_Information.Objects.maximum == 0);
+  next_step(POSIX_THREADS_PRE);
+LAST(RTEMS_SYSINIT_POSIX_THREADS)
+  assert(_POSIX_Threads_Information.Objects.maximum != 0);
+  next_step(POSIX_THREADS_POST);
 FIRST(RTEMS_SYSINIT_IDLE_THREADS)
@@ -448,6 +463,12 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TIMERS 1
+#ifdef RTEMS_POSIX_API
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
+#endif /* RTEMS_POSIX_API */
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
 #define CONFIGURE_STACK_CHECKER_ENABLED
1.8.4.5
