[PATCH 24/38] Optional POSIX Timer initialization
Tue Jan 26 15:37:50 UTC 2016
Update #2408.
 cpukit/posix/include/rtems/posix/ptimer.h    |  7 -------
 cpukit/posix/include/rtems/posix/timerimpl.h |  9 +--------
 cpukit/posix/src/ptimer.c                    | 11 ++++++++++-
 cpukit/sapi/src/posixapi.c                   |  2 --
 cpukit/score/include/rtems/sysinit.h         |  1 +
 testsuites/sptests/spsysinit01/init.c        | 17 +++++++++++++++++
 6 files changed, 29 insertions(+), 18 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/ptimer.h b/cpukit/posix/include/rtems/posix/ptimer.h
index 16ac2b8..f6de4cc 100644
--- a/cpukit/posix/include/rtems/posix/ptimer.h
+++ b/cpukit/posix/include/rtems/posix/ptimer.h
@@ -36,13 +36,6 @@ extern "C" {
 #include <rtems/posix/config.h>
- *  @brief POSIX Timer Manager Initialization
- *  This routine performs the initialization necessary for this manager.
-void _POSIX_Timer_Manager_initialization(void);
  *  @brief Create a Per-Process Timer
 int timer_create(
diff --git a/cpukit/posix/include/rtems/posix/timerimpl.h b/cpukit/posix/include/rtems/posix/timerimpl.h
index b297d32..8b5b42e 100644
--- a/cpukit/posix/include/rtems/posix/timerimpl.h
+++ b/cpukit/posix/include/rtems/posix/timerimpl.h
@@ -51,13 +51,6 @@ extern "C" {
 #endif
  *  @brief POSIX Timer Manager Timer Service Routine Helper
  *  This is the operation that is run when a timer expires.
@@ -79,7 +72,7 @@ bool _POSIX_Timer_Insert_helper(
  *  The following defines the information control block used to manage
  *  this class of objects.
-POSIX_EXTERN Objects_Information  _POSIX_Timer_Information;
+extern Objects_Information _POSIX_Timer_Information;
  *  @brief POSIX Timer Allocate
diff --git a/cpukit/posix/src/ptimer.c b/cpukit/posix/src/ptimer.c
index a1e0637..810112a 100644
--- a/cpukit/posix/src/ptimer.c
+++ b/cpukit/posix/src/ptimer.c
@@ -33,6 +33,7 @@
 #include <unistd.h>
+#include <rtems/sysinit.h>
 #include <rtems/rtems/timer.h>
@@ -44,6 +45,8 @@
 #include <rtems/posix/timerimpl.h>
+Objects_Information _POSIX_Timer_Information;
  * _POSIX_Timer_Manager_initialization
@@ -53,7 +56,7 @@
  *  the timers are stored
+static void _POSIX_Timer_Manager_initialization(void)
   _Objects_Initialize_information(
     &_POSIX_Timer_Information,  /* object information table */
@@ -72,3 +75,9 @@ void _POSIX_Timer_Manager_initialization(void)
 #endif
+RTEMS_SYSINIT_ITEM(
+  _POSIX_Timer_Manager_initialization,
+  RTEMS_SYSINIT_POSIX_TIMER,
+  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index f1997bf..f645946 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -36,7 +36,6 @@
 #include <rtems/posix/psignalimpl.h>
 #include <rtems/posix/rwlockimpl.h>
-#include <rtems/posix/timerimpl.h>
 #include <rtems/posix/spinlockimpl.h>
 #endif
@@ -59,7 +58,6 @@ void _POSIX_API_Initialize(void)
   _POSIX_Key_Manager_initialization();
   #ifdef RTEMS_POSIX_API
-    _POSIX_Timer_Manager_initialization();
     _POSIX_Barrier_Manager_initialization();
     _POSIX_RWLock_Manager_initialization();
     _POSIX_Spinlock_Manager_initialization();
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index b32723c..95865c4 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -48,6 +48,7 @@ extern "C" {
 #define RTEMS_SYSINIT_POSIX_MUTEX                000363
 #define RTEMS_SYSINIT_POSIX_MESSAGE_QUEUE        000364
 #define RTEMS_SYSINIT_POSIX_SEMAPHORE            000365
+#define RTEMS_SYSINIT_POSIX_TIMER                000366
 #define RTEMS_SYSINIT_POSIX_CLEANUP              00036a
 #define RTEMS_SYSINIT_IDLE_THREADS               000380
 #define RTEMS_SYSINIT_BSP_LIBC                   000400
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index 6854d70..1679cb6 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -34,6 +34,7 @@
 #include <rtems/posix/semaphoreimpl.h>
+#include <rtems/posix/timerimpl.h>
 #endif /* RTEMS_POSIX_API */
 #include <rtems/rtems/barrierimpl.h>
 #include <rtems/rtems/dpmemimpl.h>
@@ -98,6 +99,8 @@ typedef enum {
   POSIX_MESSAGE_QUEUE_POST,
   POSIX_SEMAPHORE_PRE,
   POSIX_SEMAPHORE_POST,
+  POSIX_TIMER_PRE,
+  POSIX_TIMER_POST,
   POSIX_CLEANUP_PRE,
   POSIX_CLEANUP_POST,
@@ -422,6 +425,18 @@ LAST(RTEMS_SYSINIT_POSIX_SEMAPHORE)
   next_step(POSIX_SEMAPHORE_POST);
+FIRST(RTEMS_SYSINIT_POSIX_TIMER)
+  assert(_POSIX_Timer_Information.maximum == 0);
+  next_step(POSIX_TIMER_PRE);
+LAST(RTEMS_SYSINIT_POSIX_TIMER)
+  assert(_POSIX_Timer_Information.maximum != 0);
+  next_step(POSIX_TIMER_POST);
 static size_t user_extensions_pre_posix_cleanup;
 FIRST(RTEMS_SYSINIT_POSIX_CLEANUP)
@@ -559,6 +574,8 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 1
+#define CONFIGURE_MAXIMUM_POSIX_TIMERS 1
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 1
1.8.4.5
