[PATCH 23/38] Optional POSIX Semaphore initialization
Tue Jan 26 15:37:49 UTC 2016
Update #2408.
 cpukit/posix/include/rtems/posix/semaphoreimpl.h |  9 +--------
 cpukit/posix/src/semaphore.c                     | 11 ++++++++++-
 cpukit/sapi/src/posixapi.c                       |  2 --
 cpukit/score/include/rtems/sysinit.h             |  1 +
 testsuites/sptests/spsysinit01/init.c            | 17 +++++++++++++++++
 5 files changed, 29 insertions(+), 11 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
index eeea51c..fe5ee44 100644
--- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
+++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
@@ -33,7 +33,7 @@ extern "C" {
  *  This defines the information control block used to manage
  *  this class of objects.
-POSIX_EXTERN Objects_Information  _POSIX_Semaphore_Information;
+extern Objects_Information _POSIX_Semaphore_Information;
  *  This defines the mapping from Score status codes to POSIX return codes.
@@ -41,13 +41,6 @@ POSIX_EXTERN Objects_Information  _POSIX_Semaphore_Information;
 extern const int
   _POSIX_Semaphore_Return_codes[CORE_SEMAPHORE_STATUS_LAST + 1];
- *  @brief POSIX Semaphore Manager Initialization
- *  This routine performs the initialization necessary for this manager.
-void _POSIX_Semaphore_Manager_initialization(void);
 RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *
   _POSIX_Semaphore_Allocate_unprotected( void )
diff --git a/cpukit/posix/src/semaphore.c b/cpukit/posix/src/semaphore.c
index 5830373..db3ae0c 100644
--- a/cpukit/posix/src/semaphore.c
+++ b/cpukit/posix/src/semaphore.c
@@ -28,9 +28,12 @@
 #include <rtems/config.h>
+#include <rtems/sysinit.h>
 #include <rtems/posix/semaphoreimpl.h>
 #include <rtems/seterr.h>
+Objects_Information _POSIX_Semaphore_Information;
  *  _POSIX_Semaphore_Manager_initialization
@@ -41,7 +44,7 @@
  *  Output parameters:  NONE
+static void _POSIX_Semaphore_Manager_initialization(void)
   _Objects_Initialize_information(
     &_POSIX_Semaphore_Information, /* object information table */
@@ -60,3 +63,9 @@ void _POSIX_Semaphore_Manager_initialization(void)
 #endif
+RTEMS_SYSINIT_ITEM(
+  _POSIX_Semaphore_Manager_initialization,
+  RTEMS_SYSINIT_POSIX_SEMAPHORE,
+  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index 8d99678..f1997bf 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -37,7 +37,6 @@
 #include <rtems/posix/psignalimpl.h>
 #include <rtems/posix/rwlockimpl.h>
 #include <rtems/posix/timerimpl.h>
-#include <rtems/posix/semaphoreimpl.h>
 #include <rtems/posix/spinlockimpl.h>
 #endif
@@ -60,7 +59,6 @@ void _POSIX_API_Initialize(void)
   _POSIX_Key_Manager_initialization();
   #ifdef RTEMS_POSIX_API
-    _POSIX_Semaphore_Manager_initialization();
     _POSIX_Timer_Manager_initialization();
     _POSIX_Barrier_Manager_initialization();
     _POSIX_RWLock_Manager_initialization();
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index bce999e..b32723c 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -47,6 +47,7 @@ extern "C" {
 #define RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE   000362
 #define RTEMS_SYSINIT_POSIX_MUTEX                000363
 #define RTEMS_SYSINIT_POSIX_MESSAGE_QUEUE        000364
+#define RTEMS_SYSINIT_POSIX_SEMAPHORE            000365
 #define RTEMS_SYSINIT_POSIX_CLEANUP              00036a
 #define RTEMS_SYSINIT_IDLE_THREADS               000380
 #define RTEMS_SYSINIT_BSP_LIBC                   000400
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index 9e97fdb..6854d70 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -33,6 +33,7 @@
+#include <rtems/posix/semaphoreimpl.h>
 #endif /* RTEMS_POSIX_API */
 #include <rtems/rtems/barrierimpl.h>
 #include <rtems/rtems/dpmemimpl.h>
@@ -95,6 +96,8 @@ typedef enum {
   POSIX_MUTEX_POST,
   POSIX_MESSAGE_QUEUE_PRE,
   POSIX_MESSAGE_QUEUE_POST,
+  POSIX_SEMAPHORE_PRE,
+  POSIX_SEMAPHORE_POST,
   POSIX_CLEANUP_PRE,
   POSIX_CLEANUP_POST,
@@ -407,6 +410,18 @@ LAST(RTEMS_SYSINIT_POSIX_MESSAGE_QUEUE)
   next_step(POSIX_MESSAGE_QUEUE_POST);
+FIRST(RTEMS_SYSINIT_POSIX_SEMAPHORE)
+  assert(_POSIX_Semaphore_Information.maximum == 0);
+  next_step(POSIX_SEMAPHORE_PRE);
+LAST(RTEMS_SYSINIT_POSIX_SEMAPHORE)
+  assert(_POSIX_Semaphore_Information.maximum != 0);
+  next_step(POSIX_SEMAPHORE_POST);
 static size_t user_extensions_pre_posix_cleanup;
 FIRST(RTEMS_SYSINIT_POSIX_CLEANUP)
@@ -542,6 +557,8 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 1
+#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 1
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 1
1.8.4.5
