[PATCH 00/10] HYP mode boot and cache manager updates for ARM and RaspberryPi specially.
Alan Cudmore alan.cudmore at gmail.com
Tue Jul 5 01:33:37 UTC 2016
I figured out my problem with the RPI 2, it was a configuration problem with my build.
So the latest RTEMS Git builds and runs on Raspberry Pi 2, Raspberry Pi A+, and Raspberry Pi Zero, all with the latest firmware.
Thanks,
Alan
> On Jul 4, 2016, at 6:29 PM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> I updated my RTEMS git and rebuilt the Pi and Pi2 BSPs.
> Pi 1 works, but Pi 2 does not boot.
> Pi 1 has a speed up on the dhrystone command:
> I get 90000 dhrystones per second.
> When I run your github pi branch, the Pi2 works with both the new and old firmware.
> The new firmware Pi 2 dhrystone command is 26315 dhrystones per second
> The old firmware Pi 2 dhrystone command is 45454 dhrystones per second.
> So something in the firmware and caches is different, I can double check the configuration.
> But first, I will have to try to figure out the differences between the RTEMS git and your github and see why the Pi 2 is not booting for me.
> Thanks,
> Alan
>> On Jul 4, 2016, at 4:17 PM, Pavel Pisa <pisa at cmp.felk.cvut.cz> wrote:
>> Hello Alan and Rohini Kulkarni,
>> On Monday 04 of July 2016 18:47:09 Alan Cudmore wrote:
>>> Hi Pavel,
>>> I can confirm that your rtems-rpi-devel branch from your github account
>>> works on the Raspberry Pi A+, Raspberry Pi Zero, and Raspberry Pi 2 with
>>> I did notice that the Dhrystone benchmark runs 3 times faster on the Pi 1
>>> than the Pi 2, but that could be the cache configuration.
>> Is this problem of the new firmware only?
>> If answer is yes, then it can be problem with providing
>> permission to control cache from SVC mode. Then some
>> register setup before switching from HYP mode could be required.
>> If it is not related to new hardware then I think that
>> there is no change in caching attributes introduced
>> by all my changes and experience of Rohini Kulkarni working
>> on RPi2 SMP project in frame of GSoC 2015 could help.
>> Code is on GitHub,
>> https://github.com/krohini1593/rtems
>> which is not merged to RTEMS mainline yet.
>> There are some changes to change cache configuration.
>> I have tried some changes in bsp_start_hook_1
>> +#include <bsp/arm-cp15-start.h>
>> -  bsp_memory_management_initialize();
>> +  uint32_t ctrl;
>> +  /* turn mmu off first in case it's on */
>> +  ctrl = arm_cp15_start_setup_mmu_and_cache(
>> +    ARM_CP15_CTRL_M | ARM_CP15_CTRL_A,  /* clear - mmu off */
>> +    ARM_CP15_CTRL_AFE
>> +  ctrl |= ARM_CP15_CTRL_Z;
>> +  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>> +    ctrl,
>> +    (uint32_t *) bsp_translation_table_base,
>> +    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
>> +    &arm_cp15_start_mmu_config_table[0],
>> +    arm_cp15_start_mmu_config_table_size
>> to ensure that ARM_CP15_CTRL_Z is set for branch predictor.
>> But I have tried some modifications in BSP and I have observed
>> no changes. RPi1 seems to run about 4 times faster in my case.
>> So it is probable that at cache is not enabled. May be only L2???
>> There can be mitchmatch between configured MMU table format/bit use
>> and the way bits are filled. I have not time to recheck that
>> yet but RPi2 code matches Cyclone Cortex-A9 BSP in CPU setup
>> so it should be OK if there is not some Broadcom specific control
>> register.
>> Best wishes,
>>             Pavel
