[2/6] add ti cpsw head file
yao0718
29171383 at qq.com
Tue Jul 5 07:15:30 UTC 2016
diff -ruN ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h
--- ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h 1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswreg.h 2016-03-18 11:38:45.324075400 +0800
@@ -0,0 +1,178 @@
+ * Copyright (c) 2012 Damjan Marion <dmarion at Freebsd.org>
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _IF_CPSWREG_H
+#define _IF_CPSWREG_H
+#define CPSW_SS_OFFSET 0x0000
+#define CPSW_SS_IDVER (CPSW_SS_OFFSET + 0x00)
+#define CPSW_SS_SOFT_RESET (CPSW_SS_OFFSET + 0x08)
+#define CPSW_SS_STAT_PORT_EN (CPSW_SS_OFFSET + 0x0C)
+#define CPSW_SS_PTYPE (CPSW_SS_OFFSET + 0x10)
+#define CPSW_SS_FLOW_CONTROL (CPSW_SS_OFFSET + 0x24)
+#define CPSW_PORT_OFFSET 0x0100
+#define CPSW_PORT_P_MAX_BLKS(p) (CPSW_PORT_OFFSET + 0x08 + ((p) * 0x100))
+#define CPSW_PORT_P_BLK_CNT(p) (CPSW_PORT_OFFSET + 0x0C + ((p) * 0x100))
+#define CPSW_PORT_P_VLAN(p) (CPSW_PORT_OFFSET + 0x14 + ((p) * 0x100))
+#define CPSW_PORT_P_TX_PRI_MAP(p) (CPSW_PORT_OFFSET + 0x118 + ((p-1) * 0x100))
+#define CPSW_PORT_P0_CPDMA_TX_PRI_MAP (CPSW_PORT_OFFSET + 0x01C)
+#define CPSW_PORT_P0_CPDMA_RX_CH_MAP (CPSW_PORT_OFFSET + 0x020)
+#define CPSW_PORT_P_SA_LO(p) (CPSW_PORT_OFFSET + 0x120 + ((p-1) * 0x100))
+#define CPSW_PORT_P_SA_HI(p) (CPSW_PORT_OFFSET + 0x124 + ((p-1) * 0x100))
+#define CPSW_CPDMA_OFFSET 0x0800
+#define CPSW_CPDMA_TX_CONTROL (CPSW_CPDMA_OFFSET + 0x04)
+#define CPSW_CPDMA_TX_TEARDOWN (CPSW_CPDMA_OFFSET + 0x08)
+#define CPSW_CPDMA_RX_CONTROL (CPSW_CPDMA_OFFSET + 0x14)
+#define CPSW_CPDMA_RX_TEARDOWN (CPSW_CPDMA_OFFSET + 0x18)
+#define CPSW_CPDMA_SOFT_RESET (CPSW_CPDMA_OFFSET + 0x1c)
+#define CPSW_CPDMA_DMACONTROL (CPSW_CPDMA_OFFSET + 0x20)
+#define CPSW_CPDMA_DMASTATUS (CPSW_CPDMA_OFFSET + 0x24)
+#define CPSW_CPDMA_RX_BUFFER_OFFSET (CPSW_CPDMA_OFFSET + 0x28)
+#define CPSW_CPDMA_TX_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0x80)
+#define CPSW_CPDMA_TX_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0x84)
+#define CPSW_CPDMA_TX_INTMASK_SET (CPSW_CPDMA_OFFSET + 0x88)
+#define CPSW_CPDMA_TX_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0x8C)
+#define CPSW_CPDMA_CPDMA_EOI_VECTOR (CPSW_CPDMA_OFFSET + 0x94)
+#define CPSW_CPDMA_RX_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0xA0)
+#define CPSW_CPDMA_RX_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0xA4)
+#define CPSW_CPDMA_RX_INTMASK_SET (CPSW_CPDMA_OFFSET + 0xA8)
+#define CPSW_CPDMA_RX_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0xAc)
+#define CPSW_CPDMA_DMA_INTSTAT_RAW (CPSW_CPDMA_OFFSET + 0xB0)
+#define CPSW_CPDMA_DMA_INTSTAT_MASKED (CPSW_CPDMA_OFFSET + 0xB4)
+#define CPSW_CPDMA_DMA_INTMASK_SET (CPSW_CPDMA_OFFSET + 0xB8)
+#define CPSW_CPDMA_DMA_INTMASK_CLEAR (CPSW_CPDMA_OFFSET + 0xBC)
+#define CPSW_CPDMA_RX_FREEBUFFER(p) (CPSW_CPDMA_OFFSET + 0x0e0 + ((p) * 0x04))
+#define CPSW_STATS_OFFSET 0x0900
+#define CPSW_STATERAM_OFFSET 0x0A00
+#define CPSW_CPDMA_TX_HDP(p) (CPSW_STATERAM_OFFSET + 0x00 + ((p) * 0x04))
+#define CPSW_CPDMA_RX_HDP(p) (CPSW_STATERAM_OFFSET + 0x20 + ((p) * 0x04))
+#define CPSW_CPDMA_TX_CP(p) (CPSW_STATERAM_OFFSET + 0x40 + ((p) * 0x04))
+#define CPSW_CPDMA_RX_CP(p) (CPSW_STATERAM_OFFSET + 0x60 + ((p) * 0x04))
+#define CPSW_CPTS_OFFSET 0x0C00
+#define CPSW_ALE_OFFSET 0x0D00
+#define CPSW_ALE_CONTROL (CPSW_ALE_OFFSET + 0x08)
+#define CPSW_ALE_CTL_ENABLE (1U << 31)
+#define CPSW_ALE_CTL_CLEAR_TBL (1 << 30)
+#define CPSW_ALE_CTL_BYPASS (1 << 4)
+#define CPSW_ALE_CTL_VLAN_AWARE (1 << 2)
+#define CPSW_ALE_TBLCTL (CPSW_ALE_OFFSET + 0x20)
+#define CPSW_ALE_TBLW2 (CPSW_ALE_OFFSET + 0x34)
+#define CPSW_ALE_TBLW1 (CPSW_ALE_OFFSET + 0x38)
+#define CPSW_ALE_TBLW0 (CPSW_ALE_OFFSET + 0x3C)
+#define ALE_MCAST(_a) ((_a[1] >> 8) & 1)
+#define ALE_MCAST_FWD (3 << 30)
+#define ALE_PORTS(_a) ((_a[2] >> 2) & 7)
+#define ALE_TYPE(_a) ((_a[1] >> 28) & 3)
+#define ALE_TYPE_ADDR 1
+#define ALE_TYPE_VLAN 2
+#define ALE_TYPE_VLAN_ADDR 3
+#define ALE_VLAN(_a) ((_a[1] >> 16) & 0xfff)
+#define ALE_VLAN_REGFLOOD(_a) ((_a[0] >> 8) & 7)
+#define ALE_VLAN_UNREGFLOOD(_a) ((_a[0] >> 16) & 7)
+#define ALE_VLAN_UNTAG(_a) ((_a[0] >> 24) & 7)
+#define ALE_VLAN_MEMBERS(_a) (_a[0] & 7)
+#define CPSW_ALE_PORTCTL(p) (CPSW_ALE_OFFSET + 0x40 + ((p) * 0x04))
+/* SL1 is at 0x0D80, SL2 is at 0x0DC0 */
+#define CPSW_SL_OFFSET 0x0D80
+#define CPSW_SL_MACCONTROL(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x04)
+#define CPSW_SL_MACTL_IFCTL_B (1 << 16)
+#define CPSW_SL_MACTL_IFCTL_A (1 << 15)
+#define CPSW_SL_MACTL_GIG (1 << 7)
+#define CPSW_SL_MACTL_GMII_ENABLE (1 << 5)
+#define CPSW_SL_MACTL_FULLDUPLEX (1 << 0)
+#define CPSW_SL_MACSTATUS(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x08)
+#define CPSW_SL_SOFT_RESET(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x0C)
+#define CPSW_SL_RX_MAXLEN(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x10)
+#define CPSW_SL_RX_PAUSE(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x18)
+#define CPSW_SL_TX_PAUSE(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x1C)
+#define CPSW_SL_RX_PRI_MAP(p) (CPSW_SL_OFFSET + (0x40 * (p)) + 0x24)
+#define MDIO_OFFSET 0x1000
+#define MDIOCONTROL (MDIO_OFFSET + 0x04)
+#define MDIOCTL_ENABLE (1 << 30)
+#define MDIOCTL_FAULTENB (1 << 18)
+#define MDIOLINKINTRAW (MDIO_OFFSET + 0x10)
+#define MDIOLINKINTMASKED (MDIO_OFFSET + 0x14)
+#define MDIOUSERACCESS0 (MDIO_OFFSET + 0x80)
+#define MDIOUSERPHYSEL0 (MDIO_OFFSET + 0x84)
+#define MDIOUSERACCESS1 (MDIO_OFFSET + 0x88)
+#define MDIOUSERPHYSEL1 (MDIO_OFFSET + 0x8C)
+#define MDIO_PHYSEL_LINKINTENB (1 << 6)
+#define MDIO_PHYACCESS_GO (1U << 31)
+#define MDIO_PHYACCESS_WRITE (1 << 30)
+#define MDIO_PHYACCESS_ACK (1 << 29)
+#define CPSW_WR_OFFSET 0x1200
+#define CPSW_WR_SOFT_RESET (CPSW_WR_OFFSET + 0x04)
+#define CPSW_WR_CONTROL (CPSW_WR_OFFSET + 0x08)
+#define CPSW_WR_INT_CONTROL (CPSW_WR_OFFSET + 0x0c)
+#define CPSW_WR_C_RX_THRESH_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x10)
+#define CPSW_WR_C_RX_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x14)
+#define CPSW_WR_C_TX_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x18)
+#define CPSW_WR_C_MISC_EN(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x1C)
+#define CPSW_WR_C_RX_THRESH_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x40)
+#define CPSW_WR_C_RX_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x44)
+#define CPSW_WR_C_TX_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x48)
+#define CPSW_WR_C_MISC_STAT(p) (CPSW_WR_OFFSET + (0x10 * (p)) + 0x4C)
+#define CPSW_WR_C_MISC_EVNT_PEND (1 << 4)
+#define CPSW_WR_C_MISC_STAT_PEND (1 << 3)
+#define CPSW_WR_C_MISC_HOST_PEND (1 << 2)
+#define CPSW_WR_C_MISC_MDIOLINK (1 << 1)
+#define CPSW_WR_C_MISC_MDIOUSER (1 << 0)
+#define CPSW_CPPI_RAM_OFFSET 0x2000
+#define CPSW_CPPI_RAM_SIZE 0x2000
+#define CPSW_MEMWINDOW_SIZE 0x4000
+#define CPDMA_BD_SOP (1 << 15)
+#define CPDMA_BD_EOP (1 << 14)
+#define CPDMA_BD_OWNER (1 << 13)
+#define CPDMA_BD_EOQ (1 << 12)
+#define CPDMA_BD_TDOWNCMPLT (1 << 11)
+#define CPDMA_BD_PKT_ERR_MASK (3 << 4)
+#define CPDMA_BD_TO_PORT (1 << 4)
+#define CPDMA_BD_PORT_MASK 3
+struct cpsw_cpdma_bd {
+ volatile uint32_t next;
+ volatile uint32_t bufptr;
+ volatile uint16_t buflen;
+ volatile uint16_t bufoff;
+ volatile uint16_t pktlen;
+ volatile uint16_t flags;
+#endif /*_IF_CPSWREG_H */
diff -ruN ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h
--- ./rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h 1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/arm/ti/cpsw/if_cpswvar.h 2016-07-02 21:43:26.205209800 +0800
@@ -0,0 +1,147 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _IF_CPSWVAR_H
+#define _IF_CPSWVAR_H
+#define CPSW_PORTS 2
+#define CPSW_INTR_COUNT 4
+/* MII BUS */
+#define CPSW_MIIBUS_RETRIES 10
+#define CPSW_MIIBUS_DELAY 2000
+#define CPSW_MAX_ALE_ENTRIES 1024
+#define CPSW_SYSCTL_COUNT 34
+#define CPSW_RESEMBLE_BUFFER_LEN 2048
+#define CPSW_RESEMBLE_BUFFER_ALIGN 4
+struct cpsw_slot {
+ uint32_t bd_offset; /* Offset of corresponding BD within CPPI RAM. */
+ bus_dmamap_t dmamap;
+ struct mbuf *mbuf;
+/* yao0718 add why cppi dma can not send when address misalign 32 bits*/
+ uint8_t *resemble;
+ uint8_t *align_res;
+ STAILQ_ENTRY(cpsw_slot) next;
+STAILQ_HEAD(cpsw_slots, cpsw_slot);
+struct cpsw_queue {
+ struct mtx lock;
+ int running;
+ struct cpsw_slots active;
+ struct cpsw_slots avail;
+ uint32_t queue_adds; /* total bufs added */
+ uint32_t queue_removes; /* total bufs removed */
+ uint32_t queue_removes_at_last_tick; /* Used by watchdog */
+ int queue_slots;
+ int active_queue_len;
+ int max_active_queue_len;
+ int avail_queue_len;
+ int max_avail_queue_len;
+ int longest_chain; /* Largest # segments in a single packet. */
+ int hdp_offset;
+struct cpsw_port {
+ device_t dev;
+ int phy;
+ int vlan;
+struct cpsw_softc {
+ device_t dev;
+ int active_slave;
+ int debug;
+ int dualemac;
+#ifndef __rtems__
+ phandle_t node;
+#endif
+ struct bintime attach_uptime; /* system uptime when attach happened. */
+ struct cpsw_port port[2];
+ /* RX and TX buffer tracking */
+ struct cpsw_queue rx, tx;
+ /* We expect 1 memory resource and 4 interrupts from the device tree. */
+ void *ih_cookie[CPSW_INTR_COUNT];
+#ifndef __rtems__
+ int mem_rid;
+ struct resource *mem_res;
+ struct resource *irq_res[CPSW_INTR_COUNT];
+#else
+ struct resource *irq_res[1+CPSW_INTR_COUNT];
+#endif
+ /* An mbuf full of nulls for TX padding. */
+ bus_dmamap_t null_mbuf_dmamap;
+ struct mbuf *null_mbuf;
+ bus_addr_t null_mbuf_paddr;
+ bus_dma_tag_t mbuf_dtag;
+ struct {
+ int resets;
+ int timer;
+ struct callout callout;
+ } watchdog;
+ /* 64-bit versions of 32-bit hardware statistics counters */
+ uint64_t shadow_stats[CPSW_SYSCTL_COUNT];
+ /* CPPI STATERAM has 512 slots for building TX/RX queues. */
+ /* TODO: Size here supposedly varies with different versions
+ of the controller. Check DaVinci specs and find a good
+ way to adjust this. One option is to have a separate
+ Device Tree parameter for number slots; another option
+ is to calculate it from the memory size in the device tree. */
+ struct cpsw_slot _slots[CPSW_CPPI_RAM_SIZE / sizeof(struct cpsw_cpdma_bd)];
+struct cpswp_softc {
+ device_t dev;
+ device_t miibus;
+ device_t pdev;
+ int media_status;
+ int unit;
+ int vlan;
+ struct bintime init_uptime; /* system uptime when init happened. */
+ struct callout mii_callout;
+ struct cpsw_softc *swsc;
+ struct ifnet *ifp;
+ struct mii_data *mii;
+ struct mtx lock;
+ uint32_t if_flags;
+ uint32_t phy;
+ uint32_t phyaccess;
+ uint32_t physel;
+#endif /*_IF_CPSWVAR_H */
------------------ Original ------------------
Date: Tue, Jul 5, 2016 03:11 PM
To: "devel"<devel at rtems.org>;
Subject: [0/6] ti cpsw driver port from freebsd for am335x
I add cpsw driver from freebsd and modify some code for my board, my board is not beagleblack, so i am not sure it can work fine in BB board,to reduce phy find process, I set phy address 4 and 6 for which phy address on my board,my board has two eth port ,I set dualmac when attach;
can somebody test it on beaglebone and merge to beaglebone bsp?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160705/af71cbe6/attachment-0001.html>
