Error while adding usb ethernet driver
Thu Jul 7 23:19:32 UTC 2016
On 7/07/2016 12:59 AM, Deval Shah wrote:
> I updated the code. Still I am not getting the debug messages.
> Can there be any other possibility ?
Could you please have a look at this code ..
https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/rtems/syslog.c#n54
and see if you can see a problem. I cannot.
> Previously I used to get messages from bcm283x_dwcotg driver.
There are also a number of low level kernel build options you can enable:
https://git.rtems.org/rtems-libbsd/tree/README.waf#n197
