Updates and Problems on "Raspberry Pi USB and Ethernet Support" Project
Tue Jul 12 05:37:32 UTC 2016
On 12/07/2016 14:41, Deval Shah wrote:
> The problem with the RaspberryPi_USB was that due to some other updates
> in mainline, I was not getting the device_printfs. So I switched back to
> the old repo of mine.
It would help if you could please debug this. It is easy to do. Just add
a printf in the syslog function and see if it is bring called. If it is
being called please check the values and logic for the priority, again
some simple prints should show this.
Thanks
