[PATCH 3/6] arm/bsps: CP15 and basic cache support entire cache clean for more architecture variants now.
Tue Jul 19 15:21:16 UTC 2016
On Sun, Jul 17, 2016 at 6:48 PM,  <pisa at cmp.felk.cvut.cz> wrote:
> From: Pavel Pisa <pisa at cmp.felk.cvut.cz>
> Next cache operations should work on most of cores now
>   rtems_cache_flush_entire_data()
>   rtems_cache_invalidate_entire_data()
>   rtems_cache_invalidate_entire_instruction()
> Instruction cache invalidate works on the first level for now only.
> Data cacache operations are extended to ensure flush/invalidate
> on all cache levels.
> The CP15 arm_cp15_data_cache_clean_all_levels() function extended
> to continue through unified levels too (ctype = 4).
>  .../arm/shared/armv467ar-basic-cache/cache_.h      | 22 +++++++++--
>  c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h |  6 ++-
>  c/src/lib/libcpu/arm/shared/include/arm-cp15.h     | 44 +++++++++++++++++++++-
>  3 files changed, 66 insertions(+), 6 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h b/c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
> index c6e1f83..2ff1ae1 100644
> --- a/c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
> +++ b/c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
> @@ -49,11 +49,14 @@ _CPU_cache_flush_data_range(
>    _ARM_Data_synchronization_barrier();
> -  arm_cp15_drain_write_buffer();
>    arm_cache_l1_flush_data_range(
>      d_addr,
>      n_bytes
> +  #if !defined(__ARM_ARCH_7A__)
> +  arm_cp15_drain_write_buffer();
> +  #endif
> + _ARM_Data_synchronization_barrier();
>  static inline void _CPU_cache_invalidate_1_data_line(const void *d_addr)
> @@ -92,6 +95,7 @@ static inline void
>  _CPU_cache_invalidate_instruction_range( const void *i_addr, size_t n_bytes)
>    arm_cache_l1_invalidate_instruction_range( i_addr, n_bytes );
> +  _ARM_Instruction_synchronization_barrier();
>  static inline void _CPU_cache_freeze_instruction(void)
> @@ -106,12 +110,23 @@ static inline void _CPU_cache_unfreeze_instruction(void)
>  static inline void _CPU_cache_flush_entire_data(void)
> -  arm_cp15_data_cache_test_and_clean();
> +  #if defined(__ARM_ARCH_7A__)
> +  arm_cp15_data_cache_clean_all_levels();
> +  #else
> +  arm_cp15_data_cache_clean_and_invalidate();
> +  #endif
>  static inline void _CPU_cache_invalidate_entire_data(void)
> +  arm_cp15_data_cache_invalidate_all_levels();
> +  #else
>    arm_cp15_data_cache_invalidate();
> +  #endif
>  static inline void _CPU_cache_enable_data(void)
> @@ -141,7 +156,8 @@ static inline void _CPU_cache_disable_data(void)
>  static inline void _CPU_cache_invalidate_entire_instruction(void)
> -  arm_cp15_instruction_cache_invalidate();
> +  arm_cache_l1_invalidate_entire_instruction();
>  static inline void _CPU_cache_enable_instruction(void)
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h b/c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h
> index 74a65c5..9caa268 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h
> @@ -329,9 +329,13 @@ static inline void arm_cache_l1_invalidate_entire_instruction( void )
>    #endif /* RTEMS_SMP */
> -  if ( ( ctrl & ARM_CP15_CTRL_Z ) == 0 ) {
> +  if ( ( ctrl & ARM_CP15_CTRL_Z ) != 0 ) {
>      arm_cp15_branch_predictor_inner_shareable_invalidate_all();
> +    #endif
> +    #if defined(__ARM_ARCH_6KZ__) || defined(__ARM_ARCH_7A__)
>      arm_cp15_branch_predictor_invalidate_all();
> +    #endif
> diff --git a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> index 52cca49..a27e50d 100644
> --- a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> +++ b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> @@ -1071,8 +1071,8 @@ arm_cp15_data_cache_invalidate_all_levels(void)
>    for (level = 0; level < loc; ++level) {
>      uint32_t ctype = arm_clidr_get_cache_type(clidr, level);
> -    /* Check if this level has a data cache */
> -    if ((ctype & 0x2) != 0) {
> +    /* Check if this level has a data cache or unified cache */
> +    if (((ctype & (0x6)) == 2) || (ctype == 4)) {
>        uint32_t ccsidr;
>        uint32_t line_power;
>        uint32_t associativity;
> @@ -1134,6 +1134,46 @@ arm_cp15_data_cache_clean_line_by_set_and_way(uint32_t set_and_way)
>  ARM_CP15_TEXT_SECTION static inline void
> +arm_cp15_data_cache_clean_all_levels(void)
> +  uint32_t clidr = arm_cp15_get_cache_level_id();
> +  uint32_t loc = arm_clidr_get_level_of_coherency(clidr);
> +  uint32_t level = 0;
> +  for (level = 0; level < loc; ++level) {
> +    uint32_t ctype = arm_clidr_get_cache_type(clidr, level);
> +      uint32_t ccsidr;
> +      uint32_t line_power;
> +      uint32_t associativity;
> +      uint32_t way;
> +      uint32_t way_shift;
> +      ccsidr = arm_cp15_get_cache_size_id_for_level(level << 1);
> +      line_power = arm_ccsidr_get_line_power(ccsidr);
> +      associativity = arm_ccsidr_get_associativity(ccsidr);
> +      way_shift = __builtin_clz(associativity - 1);
Can we use a non-GCCism here, or wrap it in to a support function?
> +      for (way = 0; way < associativity; ++way) {
> +        uint32_t num_sets = arm_ccsidr_get_num_sets(ccsidr);
> +        uint32_t set;
> +        for (set = 0; set < num_sets; ++set) {
> +          uint32_t set_way = (way << way_shift)
> +            | (set << line_power)
> +            | (level << 1);
> +          arm_cp15_data_cache_clean_line_by_set_and_way(set_way);
> +ARM_CP15_TEXT_SECTION static inline void
>  arm_cp15_data_cache_test_and_clean(void)
>    ARM_SWITCH_REGISTERS;
> 1.9.1
> devel mailing list
> devel at rtems.org
