Help required with RTEMS Capture Engine.
Fri Jul 22 00:39:15 UTC 2016
On 22/07/2016 00:39, Jennifer Averett wrote:
> If I remember correctly the capture engine should not be
> running when you print and free records.  The trace should
> have been stopped then records printed and freed so that
> the records in the buffer are visible when trace is turned
> back on.  I don't think the buffer is protected when it is running.
Thanks. This makes streaming difficult and so it will need to change at
some point in time. The pre-smp version was designed to allow streaming.
Vivek, you will have to run a trace and then stop the capture and
extract the data.
