Help required with setting up TFTP communication between QEMU instance and host machine
Fri Jul 22 19:34:57 UTC 2016
On 23/07/2016 3:47 AM, vivek kukreja wrote:
> I'm working on improving the current tracing framework of
> RTEMS(Capture Engine and Trace Linker) for GSoC 2016. In the current
> phase, I have to transport trace files from RTEMS to host machine.
> I've built rtems-libbsd drivers for xilinx_zynq_19_qemu bsp and all
> examples are building with QEMU for arm.
> The testsuite has examples of a TFTP(and NFS) client running on the
> loopback interface, but I need help with configuring the ethernet
> interface.
Please look at the rcconf01 test:
https://git.rtems.org/rtems-libbsd/tree/testsuite/rcconf01/test_main.c#n43
Create an in memory rc.conf file with:
hostname=vivek
ifconfig_cgem0="inet 1.2.3.4 netmask 255.255.255.0"
defaultrouter="1.2.3.1"
Call 'rtems_bsd_run_rc_conf_script' with the script.
> If someone has worked on setting up communication between RTEMS target
> and host machine, or has similar examples please share. Any help is
> appreciated!
If you are on Linux you need to set up a tap and then get qemu to use
the tap. I do not use Linux so I cannot help.
