[PATCH 00/10] HYP mode boot and cache manager updates for ARM and RaspberryPi specially.
Alan Cudmore
alan.cudmore at gmail.com
Tue Jul 5 03:07:06 UTC 2016
The Dhrystones are the same: 90k on the RPI 1 and 26k on the RPI 2.
I recall that when we first got the RPI 2 BSP to run, someone ( Sebastian, I think ) offered a cache configuration fix that made the RPI 2 much faster than the RPI 1, even with a single core.
But getting the RPI 2 to work again with known firmware is a great step.
Alan
> On Jul 4, 2016, at 10:20 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Jul 4, 2016 8:40 PM, "Alan Cudmore" <alan.cudmore at gmail.com <mailto:alan.cudmore at gmail.com>> wrote:
> > I figured out my problem with the RPI 2, it was a configuration problem with my build.
> > So the latest RTEMS Git builds and runs on Raspberry Pi 2, Raspberry Pi A+, and Raspberry Pi Zero, all with the latest firmware.
> How are the drystones?
> > Thanks,
> > Alan
> > > On Jul 4, 2016, at 6:29 PM, Alan Cudmore <alan.cudmore at gmail.com <mailto:alan.cudmore at gmail.com>> wrote:
> > > I updated my RTEMS git and rebuilt the Pi and Pi2 BSPs.
> > > Pi 1 works, but Pi 2 does not boot.
> > > Pi 1 has a speed up on the dhrystone command:
> > > I get 90000 dhrystones per second.
> > > When I run your github pi branch, the Pi2 works with both the new and old firmware.
> > > The new firmware Pi 2 dhrystone command is 26315 dhrystones per second
> > > The old firmware Pi 2 dhrystone command is 45454 dhrystones per second.
> > > So something in the firmware and caches is different, I can double check the configuration.
> > > But first, I will have to try to figure out the differences between the RTEMS git and your github and see why the Pi 2 is not booting for me.
> > > Thanks,
> > > Alan
> > >> On Jul 4, 2016, at 4:17 PM, Pavel Pisa <pisa at cmp.felk.cvut.cz <mailto:pisa at cmp.felk.cvut.cz>> wrote:
> > >> Hello Alan and Rohini Kulkarni,
> > >> On Monday 04 of July 2016 18:47:09 Alan Cudmore wrote:
> > >>> Hi Pavel,
> > >>> I can confirm that your rtems-rpi-devel branch from your github account
> > >>> works on the Raspberry Pi A+, Raspberry Pi Zero, and Raspberry Pi 2 with
> > >>> I did notice that the Dhrystone benchmark runs 3 times faster on the Pi 1
> > >>> than the Pi 2, but that could be the cache configuration.
> > >> Is this problem of the new firmware only?
> > >> If answer is yes, then it can be problem with providing
> > >> permission to control cache from SVC mode. Then some
> > >> register setup before switching from HYP mode could be required.
> > >> If it is not related to new hardware then I think that
> > >> there is no change in caching attributes introduced
> > >> by all my changes and experience of Rohini Kulkarni working
> > >> on RPi2 SMP project in frame of GSoC 2015 could help.
> > >> Code is on GitHub,
> > >> https://github.com/krohini1593/rtems <https://github.com/krohini1593/rtems>
> > >> which is not merged to RTEMS mainline yet.
> > >> There are some changes to change cache configuration.
> > >> I have tried some changes in bsp_start_hook_1
> > >> +#include <bsp/arm-cp15-start.h>
> > >> - bsp_memory_management_initialize();
> > >> + uint32_t ctrl;
> > >> + /* turn mmu off first in case it's on */
> > >> + ctrl = arm_cp15_start_setup_mmu_and_cache(
> > >> + ARM_CP15_CTRL_M | ARM_CP15_CTRL_A, /* clear - mmu off */
> > >> + ARM_CP15_CTRL_AFE
> > >> + ctrl |= ARM_CP15_CTRL_Z;
> > >> + arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> > >> + ctrl,
> > >> + (uint32_t *) bsp_translation_table_base,
> > >> + ARM_MMU_DEFAULT_CLIENT_DOMAIN,
> > >> + &arm_cp15_start_mmu_config_table[0],
> > >> + arm_cp15_start_mmu_config_table_size
> > >> to ensure that ARM_CP15_CTRL_Z is set for branch predictor.
> > >> But I have tried some modifications in BSP and I have observed
> > >> no changes. RPi1 seems to run about 4 times faster in my case.
> > >> So it is probable that at cache is not enabled. May be only L2???
> > >> There can be mitchmatch between configured MMU table format/bit use
> > >> and the way bits are filled. I have not time to recheck that
> > >> yet but RPi2 code matches Cyclone Cortex-A9 BSP in CPU setup
> > >> so it should be OK if there is not some Broadcom specific control
> > >> register.
> > >> Best wishes,
> > >> Pavel
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> > http://lists.rtems.org/mailman/listinfo/devel <http://lists.rtems.org/mailman/listinfo/devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160704/b81551f9/attachment-0002.html>
