[4/6] perhaps need add cache suport in head file
yao0718 29171383 at qq.com
Tue Jul 5 07:37:48 UTC 2016
in file rtems-libbsd\rtemsbsd\include\machine\rtems-bsd-cache.h
#elif defined(LIBBSP_ARM_ALTERA_CYCLONE_V_BSP_H) || \
  defined(LIBBSP_ARM_XILINX_ZYNQ_BSP_H)||defined(LIBBSP_ARM_AM335X_BSP_H)
  /* With cache, no coherency support in hardware */
  #define CPU_DATA_CACHE_ALIGNMENT 32
#elif defined(LIBBSP_ARM_LPC32XX_BSP_H)
------------------ Original ------------------
Date:  Tue, Jul 5, 2016 03:11 PM
To:  "devel"<devel at rtems.org>;
Subject:  [0/6] ti cpsw driver port from freebsd for am335x
I add cpsw driver from freebsd and modify some code for my board, my board is not beagleblack, so i am not sure it can work fine in BB board,to reduce phy find process, I  set phy address 4 and 6 for which phy address on my board,my board has two eth port ,I set dualmac when attach;
can somebody test it on beaglebone and merge to beaglebone  bsp?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160705/9acc09ac/attachment-0002.html>
