[5/6] add device define
    yao0718
    29171383 at qq.com
    Tue Jul  5 07:40:18 UTC 2016
in rtems-libbsd\rtemsbsd\include\bsp\nexus-devices.h
add
 static const rtems_bsd_device_resource cpsw0_res[] = {
                .type = RTEMS_BSD_RES_MEMORY,
                .start_request = 0,
                .start_actual = 0x4a100000
                .type = RTEMS_BSD_RES_IRQ,
                .start_request = 0,
                .start_actual = 0x28
                .start_request = 1,
                .start_actual = 0x29
                .start_request = 2,
                .start_actual = 0x2a
                .start_request = 3,
                .start_actual = 0x2b
RTEMS_BSD_DEFINE_NEXUS_DEVICE(cpsw, 0, RTEMS_ARRAY_SIZE(cpsw0_res),
    &cpsw0_res[0]);
SYSINIT_DRIVER_REFERENCE(atphy, miibus);
------------------ Original ------------------
Date:  Tue, Jul 5, 2016 03:11 PM
To:  "devel"<devel at rtems.org>;
Subject:  [0/6] ti cpsw driver port from freebsd for am335x
I add cpsw driver from freebsd and modify some code for my board, my board is not beagleblack, so i am not sure it can work fine in BB board,to reduce phy find process, I  set phy address 4 and 6 for which phy address on my board,my board has two eth port ,I set dualmac when attach;
can somebody test it on beaglebone and merge to beaglebone  bsp?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160705/e9e519a2/attachment-0002.html>
