[6/6] can somebody fix it for beaglebone?
yao0718 29171383 at qq.com
Tue Jul 5 07:47:45 UTC 2016
know issue:
1. I test this driver on my board,it's work fine
2. I did not know why cppi edma can not send package without 32bits align, so I resemble the tx packages,
    this should be improve to get more performence increase
------------------ Original ------------------
Date:  Tue, Jul 5, 2016 03:11 PM
To:  "devel"<devel at rtems.org>;
Subject:  [0/6] ti cpsw driver port from freebsd for am335x
I add cpsw driver from freebsd and modify some code for my board, my board is not beagleblack, so i am not sure it can work fine in BB board,to reduce phy find process, I  set phy address 4 and 6 for which phy address on my board,my board has two eth port ,I set dualmac when attach;
can somebody test it on beaglebone and merge to beaglebone  bsp?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160705/02143f52/attachment-0002.html>
