Serial port programming?
Wed Jun 1 04:17:12 UTC 2016
On 01/06/2016 01:50, Michael Westfall wrote:
> Can someone point me to a tutorial on how to read and write serial ports
> under RTEMS?
RTEMS supports termois. There are a number of examples of termios
programming around. A quick search turned up
https://en.wikibooks.org/wiki/Serial_Programming/termios. An 'ls /dev'
in an RTEMS shell will show you the serial ports you have available.
