Serial port programming?
Michael Westfall mwestfal at gemini.edu
Wed Jun 1 21:00:21 UTC 2016
Ah, thanks. That helps.
On Wed, Jun 1, 2016 at 12:17 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 01/06/2016 01:50, Michael Westfall wrote:
>> Can someone point me to a tutorial on how to read and write serial ports
>> under RTEMS?
> RTEMS supports termois. There are a number of examples of termios
> programming around. A quick search turned up
> https://en.wikibooks.org/wiki/Serial_Programming/termios. An 'ls /dev' in
> an RTEMS shell will show you the serial ports you have available.
> Chris
Mike Westfall
Control Systems Software Engineer
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160601/3c49f9e9/attachment-0002.html>
