Driver complaint to SD Host Controller Specification 3.0
Fri Jun 3 12:20:22 UTC 2016
On 03/06/16 13:20, Mudit Jain wrote:
> In the latest commit I have followed the FreeBSD port guidelines given
> libbsd.txt using the tools to port the code.
Sorry for being pedantic, but please follow the guidelines exactly:
"Only add lines.  If your patch contains lines starting with a '-', then
this is
wrong.  Subtract code by added `#ifndef __rtems__`.  This makes merging
easier
in the future.  For example:"
So, if you see red lines in your patches, then this is wrong.
Do not rename things in the modules unless absolutely necessary. Do not
adjust header includes, instead fix the build system.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
