Driver complaint to SD Host Controller Specification 3.0
Mudit Jain
muditjain18011995 at gmail.com
Sat Jun 4 04:09:16 UTC 2016
Hi,
Apologies regarding that.
Some of the lines that showed '-' were because changes were committed on
the old changes which were not right.
However, I have created a new branch where the commits are much cleaner.
https://github.com/spark1729/rtems-libbsd/commits/RPI_SD
On Fri, Jun 3, 2016 at 5:50 PM, Sebastian Huber <
> On 03/06/16 13:20, Mudit Jain wrote:
>> In the latest commit I have followed the FreeBSD port guidelines given
>> libbsd.txt using the tools to port the code.
> Sorry for being pedantic, but please follow the guidelines exactly:
> "Only add lines. If your patch contains lines starting with a '-', then
> this is
> wrong. Subtract code by added `#ifndef __rtems__`. This makes merging
> easier
> in the future. For example:"
> So, if you see red lines in your patches, then this is wrong.
> Do not rename things in the modules unless absolutely necessary. Do not
> adjust header includes, instead fix the build system.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160604/0cfc2af4/attachment.html>
