[PATCH 2/8] powerpc: Define bitmap defines to FALSE
Wed Jun 8 13:57:58 UTC 2016
 cpukit/score/cpu/powerpc/rtems/score/cpu.h | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 0f5c8d8..287f73d 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -920,6 +920,10 @@ void _CPU_Context_Initialize(
 #ifndef ASM
 /* Bitfield handler macros */
+#define CPU_USE_GENERIC_BITFIELD_CODE FALSE
+#define CPU_USE_GENERIC_BITFIELD_DATA FALSE
  *  This routine sets _output to the bit number of the first bit
  *  set in _value.  _value is of CPU dependent type Priority_bit_map_Word.
1.8.4.5
