testing pc386 with qemu?
Wed Jun 8 22:58:18 UTC 2016
On 09/06/2016 06:31, Gedare Bloom wrote:
> I'm not seeing output with the current pc386 BSP using qemu.
Is this the RSB qemu or another one?
> I suspect
> this is due to some combination of the changes made in the BSP or the
> printk support. Any advice?
I will take a look.
> I have tried to configure with and without USE_COM1_AS_CONSOLE=1, and
> run qemu with and without redirecting serial to stdio.
What boot flags did you supply?
