testing pc386 with qemu?
Wed Jun 8 23:57:42 UTC 2016
On Wed, Jun 8, 2016 at 6:58 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 09/06/2016 06:31, Gedare Bloom wrote:
>> I'm not seeing output with the current pc386 BSP using qemu.
> Is this the RSB qemu or another one?
RSB built, but awhile back.
QEMU emulator version 2.3.50, Copyright (c) 2003-2008 Fabrice Bellard
>> I suspect
>> this is due to some combination of the changes made in the BSP or the
>> printk support. Any advice?
> I will take a look.
>> I have tried to configure with and without USE_COM1_AS_CONSOLE=1, and
>> run qemu with and without redirecting serial to stdio.
> What boot flags did you supply?
I was using the qemu -kernel method to load the executable. I did not
try with a boot disk.
> Chris
