questions about _Thread_queue_Enqueue_critical error path
Thu Jun 9 13:17:33 UTC 2016
On 08/06/16 19:32, Gedare Bloom wrote:
> In threadqenqueue.c:101 the error path will remove the timer and
> unblock the thread.
> 1) The condition for this error is that the wait flags did not match
> the expected value. This means some other change occurred in the
> thread wait status.  I don't even know if this is possible, but if it
> does happen, why is it that unconditionally removing the Thread_Timer
> and unblocking the thread is the right thing to do?
See:
https://lists.rtems.org/pipermail/devel/2016-June/015251.html
> 2) Should this cleanup path only remove the timer if it was scheduled
> i.e. if timeout != WATCHDOG_NO_TIMEOUT?
This path is unlikely, thus not performance critical. So, I think its
better to avoid additional logic.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
