questions about _Thread_queue_Enqueue_critical error path
Thu Jun 9 15:25:49 UTC 2016
On Thu, Jun 9, 2016 at 9:17 AM, Sebastian Huber
> On 08/06/16 19:32, Gedare Bloom wrote:
>> In threadqenqueue.c:101 the error path will remove the timer and
>> unblock the thread.
>> 1) The condition for this error is that the wait flags did not match
>> the expected value. This means some other change occurred in the
>> thread wait status.  I don't even know if this is possible, but if it
>> does happen, why is it that unconditionally removing the Thread_Timer
>> and unblocking the thread is the right thing to do?
> See:
> https://lists.rtems.org/pipermail/devel/2016-June/015251.html
>> 2) Should this cleanup path only remove the timer if it was scheduled
>> i.e. if timeout != WATCHDOG_NO_TIMEOUT?
> This path is unlikely, thus not performance critical. So, I think its better
> to avoid additional logic.
OK, thanks.
