[PATCH 12/16] score: Modify release job scheduler operation
Fri Jun 17 10:51:49 UTC 2016
Pass the deadline in watchdog ticks to the scheduler.
 cpukit/rtems/src/ratemonperiod.c                 | 7 ++++---
 cpukit/score/include/rtems/score/scheduler.h     | 4 ++--
 cpukit/score/include/rtems/score/schedulercbs.h  | 2 +-
 cpukit/score/include/rtems/score/scheduleredf.h  | 2 +-
 cpukit/score/include/rtems/score/schedulerimpl.h | 6 +++---
 cpukit/score/include/rtems/score/watchdogimpl.h  | 8 ++++++--
 cpukit/score/src/schedulercbsreleasejob.c        | 2 +-
 cpukit/score/src/schedulerdefaultreleasejob.c    | 8 ++++----
 cpukit/score/src/scheduleredfreleasejob.c        | 5 ++---
 9 files changed, 24 insertions(+), 20 deletions(-)
diff --git a/cpukit/rtems/src/ratemonperiod.c b/cpukit/rtems/src/ratemonperiod.c
index 1a13731..771f9c1 100644
--- a/cpukit/rtems/src/ratemonperiod.c
+++ b/cpukit/rtems/src/ratemonperiod.c
@@ -71,20 +71,21 @@ static void _Rate_monotonic_Release_job(
   Per_CPU_Control *cpu_self;
+  uint64_t deadline;
   cpu_self = _Thread_Dispatch_disable_critical( lock_context );
   _Rate_monotonic_Release( owner, lock_context );
-  _Scheduler_Release_job( owner, next_length );
   _ISR_lock_ISR_disable( lock_context );
-  _Watchdog_Per_CPU_insert_relative(
+  deadline = _Watchdog_Per_CPU_insert_relative(
     &the_period->Timer,
     cpu_self,
     next_length
   _ISR_lock_ISR_enable( lock_context );
+  _Scheduler_Release_job( owner, deadline );
   _Thread_Dispatch_enable( cpu_self );
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index c4e2bb9..f7045c5 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -145,7 +145,7 @@ typedef struct {
   void ( *release_job ) (
     const Scheduler_Control *,
     Thread_Control *,
-    uint32_t
+    uint64_t
   /** @see _Scheduler_Tick() */
@@ -521,7 +521,7 @@ void _Scheduler_default_Update_priority(
 void _Scheduler_default_Release_job(
   const Scheduler_Control *scheduler,
   Thread_Control          *the_thread,
-  uint32_t                 deadline
+  uint64_t                 deadline
diff --git a/cpukit/score/include/rtems/score/schedulercbs.h b/cpukit/score/include/rtems/score/schedulercbs.h
index 4e03e11..fea10d5 100644
--- a/cpukit/score/include/rtems/score/schedulercbs.h
+++ b/cpukit/score/include/rtems/score/schedulercbs.h
@@ -179,7 +179,7 @@ Scheduler_Void_or_thread _Scheduler_CBS_Unblock(
 void _Scheduler_CBS_Release_job (
-  uint32_t                 length
+  uint64_t                 length
diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
index 8dfc187..562620a 100644
--- a/cpukit/score/include/rtems/score/scheduleredf.h
+++ b/cpukit/score/include/rtems/score/scheduleredf.h
@@ -252,7 +252,7 @@ Scheduler_Void_or_thread _Scheduler_EDF_Yield(
 void _Scheduler_EDF_Release_job (
-  uint32_t                 deadline
+  uint64_t                 deadline
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index fad7ecc..2ea27b8 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -524,16 +524,16 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Update_priority(
  * @brief Releases a job of a thread with respect to the scheduler.
  * @param[in] the_thread The thread.
- * @param[in] length The period length.
+ * @param[in] deadline The deadline in watchdog ticks since boot.
 RTEMS_INLINE_ROUTINE void _Scheduler_Release_job(
-  uint32_t        length
+  uint64_t        deadline
   const Scheduler_Control *scheduler = _Scheduler_Get( the_thread );
-  ( *scheduler->Operations.release_job )( scheduler, the_thread, length );
+  ( *scheduler->Operations.release_job )( scheduler, the_thread, deadline );
diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
index 2b24cc6..b76a51a 100644
--- a/cpukit/score/include/rtems/score/watchdogimpl.h
+++ b/cpukit/score/include/rtems/score/watchdogimpl.h
@@ -339,23 +339,27 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_release_critical(
   _ISR_lock_Release( &cpu->Watchdog.Lock, lock_context );
-RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_insert_relative(
+RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_relative(
   Watchdog_Control *the_watchdog,
   Per_CPU_Control  *cpu,
   uint32_t          ticks
   ISR_lock_Context lock_context;
+  uint64_t expire;
   _Watchdog_Set_CPU( the_watchdog, cpu );
   _Watchdog_Per_CPU_acquire_critical( cpu, &lock_context );
+  expire = cpu->Watchdog.ticks + ticks;
   _Watchdog_Insert(
     &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ],
     the_watchdog,
-    cpu->Watchdog.ticks + ticks
+    expire
   _Watchdog_Per_CPU_release_critical( cpu, &lock_context );
+  return expire;
 RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_insert_absolute(
diff --git a/cpukit/score/src/schedulercbsreleasejob.c b/cpukit/score/src/schedulercbsreleasejob.c
index b820829..124c02b 100644
--- a/cpukit/score/src/schedulercbsreleasejob.c
+++ b/cpukit/score/src/schedulercbsreleasejob.c
@@ -24,7 +24,7 @@
 void _Scheduler_CBS_Release_job(
-  uint32_t                 deadline
+  uint64_t                 deadline
   Scheduler_CBS_Node   *node;
diff --git a/cpukit/score/src/schedulerdefaultreleasejob.c b/cpukit/score/src/schedulerdefaultreleasejob.c
index 90593ab..db4ab0e 100644
--- a/cpukit/score/src/schedulerdefaultreleasejob.c
+++ b/cpukit/score/src/schedulerdefaultreleasejob.c
@@ -24,10 +24,10 @@
-  uint32_t                 deadline
+  uint64_t                 deadline
-  ( void ) scheduler;
-  ( void ) the_thread;
-  ( void ) deadline;
+  (void) scheduler;
+  (void) the_thread;
+  (void) deadline;
diff --git a/cpukit/score/src/scheduleredfreleasejob.c b/cpukit/score/src/scheduleredfreleasejob.c
index 2c3db65..b7c83a5 100644
--- a/cpukit/score/src/scheduleredfreleasejob.c
+++ b/cpukit/score/src/scheduleredfreleasejob.c
@@ -25,7 +25,7 @@
 void _Scheduler_EDF_Release_job(
-  uint32_t                 deadline
+  uint64_t                 deadline
   Priority_Control new_priority;
@@ -35,8 +35,7 @@ void _Scheduler_EDF_Release_job(
   if (deadline) {
     /* Initializing or shifting deadline. */
-    new_priority = (_Watchdog_Ticks_since_boot + deadline)
-                   & ~SCHEDULER_EDF_PRIO_MSB;
+    new_priority = (uint32_t) deadline & ~SCHEDULER_EDF_PRIO_MSB;
   else {
     /* Switch back to background priority. */
1.8.4.5
