[PATCH 11/16] score: Remove hidden deadline overrule for CBS
Fri Jun 17 10:51:48 UTC 2016
Do what the user commands.  Maybe we should add a rtems_cbs_period()
that calls rtems_rate_monotonic_period() with the right parameter.
 cpukit/score/src/schedulercbsreleasejob.c | 30 ++++++++----------------------
 1 file changed, 8 insertions(+), 22 deletions(-)
diff --git a/cpukit/score/src/schedulercbsreleasejob.c b/cpukit/score/src/schedulercbsreleasejob.c
index a9f8e33..b820829 100644
--- a/cpukit/score/src/schedulercbsreleasejob.c
+++ b/cpukit/score/src/schedulercbsreleasejob.c
@@ -20,8 +20,6 @@
 #endif
 #include <rtems/score/schedulercbsimpl.h>
-#include <rtems/score/threadimpl.h>
-#include <rtems/score/watchdogimpl.h>
 void _Scheduler_CBS_Release_job(
   const Scheduler_Control *scheduler,
@@ -29,28 +27,16 @@ void _Scheduler_CBS_Release_job(
   uint32_t                 deadline
-  Scheduler_CBS_Node   *node = _Scheduler_CBS_Thread_get_node( the_thread );
-  Scheduler_CBS_Server *serv_info = node->cbs_server;
-  Priority_Control      new_priority;
-  Priority_Control      unused;
+  Scheduler_CBS_Node   *node;
+  Scheduler_CBS_Server *serv_info;
-  if (deadline) {
-    /* Initializing or shifting deadline. */
-    if (serv_info)
-      new_priority = (_Watchdog_Ticks_since_boot + serv_info->parameters.deadline)
-        & ~SCHEDULER_EDF_PRIO_MSB;
-    else
-      new_priority = (_Watchdog_Ticks_since_boot + deadline)
-  else {
-    /* Switch back to background priority. */
-    new_priority = the_thread->Start.initial_priority;
+  _Scheduler_EDF_Release_job( scheduler, the_thread, deadline );
+  node = _Scheduler_CBS_Thread_get_node( the_thread );
+  serv_info = node->cbs_server;
   /* Budget replenishment for the next job. */
-  if (serv_info)
+  if ( serv_info != NULL ) {
     the_thread->cpu_time_budget = serv_info->parameters.budget;
-  _Thread_Set_priority( the_thread, new_priority, &unused, true );
1.8.4.5
