testing pc386 with qemu?
    Pavel Pisa
    ppisa4lists at pikron.com
    Sun Jun 19 14:06:45 UTC 2016
Hello,
On Thursday 09 of June 2016 02:54:17 Chris Johns wrote:
> On 09/06/2016 09:57, Gedare Bloom wrote:
> > On Wed, Jun 8, 2016 at 6:58 PM, Chris Johns <chrisj at rtems.org> wrote:
> >> On 09/06/2016 06:31, Gedare Bloom wrote:
> >>> I'm not seeing output with the current pc386 BSP using qemu.
> >> Is this the RSB qemu or another one?
> > RSB built, but awhile back.
> > QEMU emulator version 2.3.50, Copyright (c) 2003-2008 Fabrice Bellard
> Thanks.
> >>> I suspect
> >>> this is due to some combination of the changes made in the BSP or the
> >>> printk support. Any advice?
> >> I will take a look.
> >>> I have tried to configure with and without USE_COM1_AS_CONSOLE=1, and
> >>> run qemu with and without redirecting serial to stdio.
> >> What boot flags did you supply?
> > I was using the qemu -kernel method to load the executable. I did not
> > try with a boot disk.
> I have never tried this with the i386. I suppose the multiboot and
> related paths are fine with this, they should be.
I have rebuild RTEMS from actual head (I hope make rebuild right files
according to the dependencies) and run it by QEMU
  QEMU emulator version 2.6.0, Copyright (c) 2003-2008 Fabrice Bellard
 qemu-system-x86_64 -enable-kvm -kernel $APP_BINARY \
      -vga cirrus \
      -net nic,vlan=0,model=e1000 -net user,vlan=0 \
      -append "--console=com1" \
      -serial stdio \
and output appears right on the console.
I have tested without --console=com1 argument and output
goes to QEMU emulated VESA screen.
So the run of RTEMS through -kernel option seems to work
(at least on my computer).
Best wishes,
              Pavel
