testing pc386 with qemu?
Thu Jun 9 00:54:17 UTC 2016
On 09/06/2016 09:57, Gedare Bloom wrote:
> On Wed, Jun 8, 2016 at 6:58 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 09/06/2016 06:31, Gedare Bloom wrote:
>>> I'm not seeing output with the current pc386 BSP using qemu.
>> Is this the RSB qemu or another one?
> RSB built, but awhile back.
> QEMU emulator version 2.3.50, Copyright (c) 2003-2008 Fabrice Bellard
Thanks.
>>> I suspect
>>> this is due to some combination of the changes made in the BSP or the
>>> printk support. Any advice?
>> I will take a look.
>>> I have tried to configure with and without USE_COM1_AS_CONSOLE=1, and
>>> run qemu with and without redirecting serial to stdio.
>> What boot flags did you supply?
> I was using the qemu -kernel method to load the executable. I did not
> try with a boot disk.
I have never tried this with the i386. I suppose the multiboot and
related paths are fine with this, they should be.
