ARM SMP Clock driver errors
    Sebastian Huber
    Tue Jun 21 05:29:15 UTC 2016
On 20/06/16 15:40, Darshit Shah wrote:
> Hi,
> Last week the clock driver for SMP ARM BSPs was fixed which allowed me
> to start executing the SMP tests for my GSoC project. However, today I
> seem to be stuck with a clock driver issue again.
> When I try to execute SMP tests, the tests exit with no output and a
> exit code of 0. On trying to run them in QEMU and breaking on
> _Terminate(), I found out that the tests exit because of an
> `RTEMS_FATAL_SOURCE_BSP` error which propagates from the
> `a9mpcore_clock_secondary_initialization` method. The complete
> backtrace is:
In this case something is wrong with your BSP build. In bspopts.h you
must find this:
find -name bspopts.h | xargs grep CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR
./arm-rtems4.12/c/realview_pbx_a9_qemu_smp/lib/libbsp/arm/realview-pbx-a9/include/bspopts.h:#define
CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR 1
./arm-rtems4.12/realview_pbx_a9_qemu_smp/lib/include/bspopts.h:#define
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
