ARM SMP Clock driver errors
Wed Jun 22 07:33:55 UTC 2016
On 21/06/16 07:29, Sebastian Huber wrote:
> On 20/06/16 15:40, Darshit Shah wrote:
>> Hi,
>> Last week the clock driver for SMP ARM BSPs was fixed which allowed
>> me to start executing the SMP tests for my GSoC project. However,
>> today I seem to be stuck with a clock driver issue again.
>> When I try to execute SMP tests, the tests exit with no output and a
>> exit code of 0. On trying to run them in QEMU and breaking on
>> _Terminate(), I found out that the tests exit because of an
>> `RTEMS_FATAL_SOURCE_BSP` error which propagates from the
>> `a9mpcore_clock_secondary_initialization` method. The complete
>> backtrace is:
> In this case something is wrong with your BSP build. In bspopts.h you
> must find this:
> find -name bspopts.h | xargs grep CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR
> ./arm-rtems4.12/c/realview_pbx_a9_qemu_smp/lib/libbsp/arm/realview-pbx-a9/include/bspopts.h:#define
> CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR 1
> ./arm-rtems4.12/realview_pbx_a9_qemu_smp/lib/include/bspopts.h:#define
I checked commit 3d9fd2ce55575e603fa9e781cc66f553e917fd3b and everything
(except some timing dependent tests) works fine for the
realview_pbx_a9_qemu and realview_pbx_a9_qemu_smp BSPs.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
