[PATCH 3/8] score: Rename Per_CPU_Control::started
Thu Mar 3 14:47:50 UTC 2016
Rename Per_CPU_Control::started into Per_CPU_Control::online to match
standard nomenclature.
 cpukit/score/include/rtems/score/percpu.h | 6 +++---
 cpukit/score/src/smp.c                    | 4 ++--
 cpukit/score/src/threadcreateidle.c       | 2 +-
 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 4ad530f..2b05b78 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -364,7 +364,7 @@ typedef struct Per_CPU_Control {
      * @brief Indicates if the processor has been successfully started via
      * _CPU_SMP_Start_processor().
-    bool started;
+    bool online;
   #endif
   Per_CPU_Stats Stats;
@@ -523,12 +523,12 @@ static inline struct _Thread_Control *_Per_CPU_Get_executing(
   return cpu->executing;
-static inline bool _Per_CPU_Is_processor_started(
+static inline bool _Per_CPU_Is_processor_online(
   const Per_CPU_Control *cpu
 #if defined( RTEMS_SMP )
-  return cpu->started;
+  return cpu->online;
 #else
   (void) cpu;
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index a5562eb..b2713f1 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -61,7 +61,7 @@ static void _SMP_Start_processors( uint32_t cpu_count )
-    cpu->started = started;
+    cpu->online = started;
     if ( started ) {
       Scheduler_Context *context =
@@ -119,7 +119,7 @@ void _SMP_Request_start_multitasking( void )
   for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
     Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
-    if ( _Per_CPU_Is_processor_started( cpu ) ) {
+    if ( _Per_CPU_Is_processor_online( cpu ) ) {
       _Per_CPU_State_change( cpu, PER_CPU_STATE_REQUEST_START_MULTITASKING );
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index a07e238..5608040 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -90,7 +90,7 @@ void _Thread_Create_idle( void )
       _Thread_Create_idle_for_cpu( cpu );
1.8.4.5
