[PATCH 3/8] score: Rename Per_CPU_Control::started
    Joel Sherrill
    joel at rtems.org
    Thu Mar  3 15:07:32 UTC 2016
Looks good.
On Thu, Mar 3, 2016 at 8:47 AM, Sebastian Huber <
> Rename Per_CPU_Control::started into Per_CPU_Control::online to match
> standard nomenclature.
>  cpukit/score/include/rtems/score/percpu.h | 6 +++---
>  cpukit/score/src/smp.c                    | 4 ++--
>  cpukit/score/src/threadcreateidle.c       | 2 +-
>  3 files changed, 6 insertions(+), 6 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/percpu.h
> b/cpukit/score/include/rtems/score/percpu.h
> index 4ad530f..2b05b78 100644
> --- a/cpukit/score/include/rtems/score/percpu.h
> +++ b/cpukit/score/include/rtems/score/percpu.h
> @@ -364,7 +364,7 @@ typedef struct Per_CPU_Control {
>       * @brief Indicates if the processor has been successfully started via
>       * _CPU_SMP_Start_processor().
> -    bool started;
> +    bool online;
>    #endif
>    Per_CPU_Stats Stats;
> @@ -523,12 +523,12 @@ static inline struct _Thread_Control
> *_Per_CPU_Get_executing(
>    return cpu->executing;
> -static inline bool _Per_CPU_Is_processor_started(
> +static inline bool _Per_CPU_Is_processor_online(
>    const Per_CPU_Control *cpu
>  #if defined( RTEMS_SMP )
> -  return cpu->started;
> +  return cpu->online;
>  #else
>    (void) cpu;
> diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
> index a5562eb..b2713f1 100644
> --- a/cpukit/score/src/smp.c
> +++ b/cpukit/score/src/smp.c
> @@ -61,7 +61,7 @@ static void _SMP_Start_processors( uint32_t cpu_count )
> -    cpu->started = started;
> +    cpu->online = started;
>      if ( started ) {
>        Scheduler_Context *context =
> @@ -119,7 +119,7 @@ void _SMP_Request_start_multitasking( void )
>    for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
>      Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
> -    if ( _Per_CPU_Is_processor_started( cpu ) ) {
> +    if ( _Per_CPU_Is_processor_online( cpu ) ) {
>        _Per_CPU_State_change( cpu,
> PER_CPU_STATE_REQUEST_START_MULTITASKING );
> diff --git a/cpukit/score/src/threadcreateidle.c
> b/cpukit/score/src/threadcreateidle.c
> index a07e238..5608040 100644
> --- a/cpukit/score/src/threadcreateidle.c
> +++ b/cpukit/score/src/threadcreateidle.c
> @@ -90,7 +90,7 @@ void _Thread_Create_idle( void )
>        _Thread_Create_idle_for_cpu( cpu );
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160303/698f1dd0/attachment.html>
