Policy for RSB branches for 4.9, 4.10 and 4.11
Sebastian Huber
Fri Mar 4 12:46:29 UTC 2016
On 28/02/16 00:07, Chris Johns wrote:
> Hi,
> Should we create branches for 4.9 and 4.10 in the RSB repo?
> Should the 4.9, 4.10 and 4.11 build set files and config scripts be
> removed from master?
> I do not see the point of maintaining the branches for releases and the
> master and I can see a situation where the 4.11 build on master, ie
> currently 4.12, is wrong but noticeable so.
In case branches are used, then we should remove the corresponding
versions from the master. Giving users the option to build the tools for
4.10 from the master */4.10 directory or the 4.10 branch makes no sense.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
