[PATCH 04/17] pc386/configure.ac: Delete incorrect and unused AM_CONDITIONAL
Wed Mar 9 22:24:49 UTC 2016
 c/src/lib/libbsp/i386/pc386/configure.ac | 1 -
 1 file changed, 1 deletion(-)
diff --git a/c/src/lib/libbsp/i386/pc386/configure.ac b/c/src/lib/libbsp/i386/pc386/configure.ac
index 469d5f5..17b7d02 100644
--- a/c/src/lib/libbsp/i386/pc386/configure.ac
+++ b/c/src/lib/libbsp/i386/pc386/configure.ac
@@ -34,7 +34,6 @@ AM_CONDITIONAL(RTEMS_VGA,[test "$BSP_ENABLE_VGA" = "1"])
 RTEMS_BSPOPTS_SET([BSP_ENABLE_COM1_COM4],[*],[1])
 RTEMS_BSPOPTS_HELP([BSP_ENABLE_COM1_COM4],
 [Set if COM1..COM4 support is enabled.])
-AM_CONDITIONAL(RTEMS_VGA,[test "$BSP_ENABLE_COM1_COM4" = "1"])
 RTEMS_BSPOPTS_SET([BSP_ENABLE_IDE],[edison],[0])
 RTEMS_BSPOPTS_SET([BSP_ENABLE_IDE],[*],[1])
1.8.3.1
