[PATCH 09/17] pc386: Add PCI UART support
Wed Mar 9 22:24:54 UTC 2016
 c/src/lib/libbsp/i386/pc386/Makefile.am            |   1 +
 c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c | 398 +++++++++++++++++++++
 c/src/lib/libbsp/i386/pc386/include/bsp.h          |   4 +
 c/src/lib/libbsp/i386/pc386/startup/bspstart.c     |   5 +
 4 files changed, 408 insertions(+)
 create mode 100644 c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
index fc73afd..c54307f 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -130,6 +130,7 @@ libbsp_a_SOURCES += console/conscfg.c
 libbsp_a_SOURCES += console/printk_support.c
 libbsp_a_SOURCES += console/exar17d15x.c
 libbsp_a_SOURCES += console/rtd316.c
+libbsp_a_SOURCES += console/uart_bus_pci.c
 # gdb
 libbsp_a_SOURCES += ../../i386/shared/comm/i386-stub.c
diff --git a/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c b/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
new file mode 100644
index 0000000..36afb73
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/console/uart_bus_pci.c
@@ -0,0 +1,398 @@
+ * This file was brought over from FreeBSD for the PCI device table.
+ * The code for using the table is RTEMS specific is also under the
+ * FreeBSD license.
+ * COPYRIGHT (c) 1989-2012.
+ * On-Line Applications Research Corporation (OAR).
+ * Copyright (c) 2006 Marcel Moolenaar
+ * Copyright (c) 2001 M. Warner Losh
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#ifdef __rtems__
+#include <stddef.h>
+#include <stdint.h>
+#else
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/conf.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <machine/bus.h>
+#include <sys/rman.h>
+#include <machine/resource.h>
+#include <dev/pci/pcivar.h>
+#include <dev/uart/uart.h>
+#include <dev/uart/uart_bus.h>
+#endif
+#define	DEFAULT_RCLK	1843200
+#ifndef __rtems__
+static int uart_pci_probe(device_t dev);
+static device_method_t uart_pci_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		uart_pci_probe),
+	DEVMETHOD(device_attach,	uart_bus_attach),
+	DEVMETHOD(device_detach,	uart_bus_detach),
+	DEVMETHOD(device_resume,	uart_bus_resume),
+	DEVMETHOD_END
+static driver_t uart_pci_driver = {
+	uart_driver_name,
+	uart_pci_methods,
+	sizeof(struct uart_softc),
+#endif
+struct pci_id {
+	uint16_t	vendor;
+	uint16_t	device;
+	uint16_t	subven;
+	uint16_t	subdev;
+	const char	*desc;
+	int		rid;
+	int		rclk;
+	int		regshft;
+static const struct pci_id pci_ns8250_ids[] = {
+{ 0x1028, 0x0008, 0xffff, 0, "Dell Remote Access Card III", 0x14,
+	128 * DEFAULT_RCLK },
+{ 0x1028, 0x0012, 0xffff, 0, "Dell RAC 4 Daughter Card Virtual UART", 0x14,
+{ 0x1033, 0x0074, 0x1033, 0x8014, "NEC RCV56ACF 56k Voice Modem", 0x10 },
+{ 0x1033, 0x007d, 0x1033, 0x8012, "NEC RS232C", 0x10 },
+{ 0x103c, 0x1048, 0x103c, 0x1227, "HP Diva Serial [GSP] UART - Powerbar SP2",
+	0x10 },
+{ 0x103c, 0x1048, 0x103c, 0x1301, "HP Diva RMP3", 0x14 },
+{ 0x103c, 0x1290, 0xffff, 0, "HP Auxiliary Diva Serial Port", 0x18 },
+{ 0x103c, 0x3301, 0xffff, 0, "HP iLO serial port", 0x10 },
+{ 0x11c1, 0x0480, 0xffff, 0, "Agere Systems Venus Modem (V90, 56KFlex)", 0x14 },
+{ 0x115d, 0x0103, 0xffff, 0, "Xircom Cardbus Ethernet + 56k Modem", 0x10 },
+{ 0x1282, 0x6585, 0xffff, 0, "Davicom 56PDV PCI Modem", 0x10 },
+{ 0x12b9, 0x1008, 0xffff, 0, "3Com 56K FaxModem Model 5610", 0x10 },
+{ 0x131f, 0x1000, 0xffff, 0, "Siig CyberSerial (1-port) 16550", 0x18 },
+{ 0x131f, 0x1001, 0xffff, 0, "Siig CyberSerial (1-port) 16650", 0x18 },
+{ 0x131f, 0x1002, 0xffff, 0, "Siig CyberSerial (1-port) 16850", 0x18 },
+{ 0x131f, 0x2000, 0xffff, 0, "Siig CyberSerial (1-port) 16550", 0x10 },
+{ 0x131f, 0x2001, 0xffff, 0, "Siig CyberSerial (1-port) 16650", 0x10 },
+{ 0x131f, 0x2002, 0xffff, 0, "Siig CyberSerial (1-port) 16850", 0x10 },
+{ 0x135c, 0x0190, 0xffff, 0, "Quatech SSCLP-100", 0x18 },
+{ 0x135c, 0x01c0, 0xffff, 0, "Quatech SSCLP-200/300", 0x18 },
+{ 0x135e, 0x7101, 0xffff, 0, "Sealevel Systems Single Port RS-232/422/485/530",
+	0x18 },
+{ 0x1407, 0x0110, 0xffff, 0, "Lava Computer mfg DSerial-PCI Port A", 0x10 },
+{ 0x1407, 0x0111, 0xffff, 0, "Lava Computer mfg DSerial-PCI Port B", 0x10 },
+{ 0x1407, 0x0510, 0xffff, 0, "Lava SP Serial 550 PCI", 0x10 },
+{ 0x1409, 0x7168, 0x1409, 0x4025, "Timedia Technology Serial Port", 0x10,
+	8 * DEFAULT_RCLK },
+{ 0x1409, 0x7168, 0x1409, 0x4027, "Timedia Technology Serial Port", 0x10,
+{ 0x1409, 0x7168, 0x1409, 0x4028, "Timedia Technology Serial Port", 0x10,
+{ 0x1409, 0x7168, 0x1409, 0x5025, "Timedia Technology Serial Port", 0x10,
+{ 0x1409, 0x7168, 0x1409, 0x5027, "Timedia Technology Serial Port", 0x10,
+{ 0x1415, 0x950b, 0xffff, 0, "Oxford Semiconductor OXCB950 Cardbus 16950 UART",
+	0x10, 16384000 },
+{ 0x1415, 0xc120, 0xffff, 0, "Oxford Semiconductor OXPCIe952 PCIe 16950 UART",
+	0x10 },
+{ 0x14e4, 0x4344, 0xffff, 0, "Sony Ericsson GC89 PC Card", 0x10},
+{ 0x151f, 0x0000, 0xffff, 0, "TOPIC Semiconductor TP560 56k modem", 0x10 },
+{ 0x1fd4, 0x1999, 0x1fd4, 0x0001, "Sunix SER5xxxx Serial Port", 0x10,
+{ 0x8086, 0x0f0a, 0xffff, 0, "Intel ValleyView LPIO1 HSUART#1", 0x10,
+	24 * DEFAULT_RCLK, 2 },
+{ 0x8086, 0x0f0c, 0xffff, 0, "Intel ValleyView LPIO1 HSUART#2", 0x10,
+{ 0x8086, 0x1c3d, 0xffff, 0, "Intel AMT - KT Controller", 0x10 },
+{ 0x8086, 0x1d3d, 0xffff, 0, "Intel C600/X79 Series Chipset KT Controller", 0x10 },
+{ 0x8086, 0x2a07, 0xffff, 0, "Intel AMT - PM965/GM965 KT Controller", 0x10 },
+{ 0x8086, 0x2a47, 0xffff, 0, "Mobile 4 Series Chipset KT Controller", 0x10 },
+{ 0x8086, 0x2e17, 0xffff, 0, "4 Series Chipset Serial KT Controller", 0x10 },
+{ 0x8086, 0x3b67, 0xffff, 0, "5 Series/3400 Series Chipset KT Controller",
+	0x10 },
+{ 0x8086, 0x8811, 0xffff, 0, "Intel EG20T Serial Port 0", 0x10 },
+{ 0x8086, 0x8812, 0xffff, 0, "Intel EG20T Serial Port 1", 0x10 },
+{ 0x8086, 0x8813, 0xffff, 0, "Intel EG20T Serial Port 2", 0x10 },
+{ 0x8086, 0x8814, 0xffff, 0, "Intel EG20T Serial Port 3", 0x10 },
+{ 0x8086, 0x8c3d, 0xffff, 0, "Intel Lynx Point KT Controller", 0x10 },
+{ 0x8086, 0x8cbd, 0xffff, 0, "Intel Wildcat Point KT Controller", 0x10 },
+{ 0x8086, 0x9c3d, 0xffff, 0, "Intel Lynx Point-LP HECI KT", 0x10 },
+{ 0x9710, 0x9820, 0x1000, 1, "NetMos NM9820 Serial Port", 0x10 },
+{ 0x9710, 0x9835, 0x1000, 1, "NetMos NM9835 Serial Port", 0x10 },
+{ 0x9710, 0x9865, 0xa000, 0x1000, "NetMos NM9865 Serial Port", 0x10 },
+{ 0x9710, 0x9900, 0xa000, 0x1000,
+	"MosChip MCS9900 PCIe to Peripheral Controller", 0x10 },
+{ 0x9710, 0x9901, 0xa000, 0x1000,
+	"MosChip MCS9901 PCIe to Peripheral Controller", 0x10 },
+{ 0x9710, 0x9904, 0xa000, 0x1000,
+	"MosChip MCS9904 PCIe to Peripheral Controller", 0x10 },
+{ 0x9710, 0x9922, 0xa000, 0x1000,
+	"MosChip MCS9922 PCIe to Peripheral Controller", 0x10 },
+{ 0xdeaf, 0x9051, 0xffff, 0, "Middle Digital PC Weasel Serial Port", 0x10 },
+{ 0xffff, 0, 0xffff, 0, NULL, 0, 0}
+#ifndef __rtems__
+const static struct pci_id *
+uart_pci_match(device_t dev, const struct pci_id *id)
+	uint16_t device, subdev, subven, vendor;
+	vendor = pci_get_vendor(dev);
+	device = pci_get_device(dev);
+	while (id->vendor != 0xffff &&
+	    (id->vendor != vendor || id->device != device))
+		id++;
+	if (id->vendor == 0xffff)
+		return (NULL);
+	if (id->subven == 0xffff)
+		return (id);
+	subven = pci_get_subvendor(dev);
+	subdev = pci_get_subdevice(dev);
+	while (id->vendor == vendor && id->device == device &&
+	    (id->subven != subven || id->subdev != subdev))
+		id++;
+	return ((id->vendor == vendor && id->device == device) ? id : NULL);
+static int
+uart_pci_probe(device_t dev)
+	struct uart_softc *sc;
+	const struct pci_id *id;
+	int result;
+	sc = device_get_softc(dev);
+	id = uart_pci_match(dev, pci_ns8250_ids);
+	if (id != NULL) {
+		sc->sc_class = &uart_ns8250_class;
+		goto match;
+	/* Add checks for non-ns8250 IDs here. */
+	return (ENXIO);
+ match:
+	result = uart_bus_probe(dev, id->regshft, id->rclk, id->rid, 0);
+	/* Bail out on error. */
+	if (result > 0)
+		return (result);
+	/* Set/override the device description. */
+	if (id->desc)
+		device_set_desc(dev, id->desc);
+	return (result);
+DRIVER_MODULE(uart, pci, uart_pci_driver, uart_devclass, NULL, NULL);
+#endif
+#ifdef __rtems__
+#include <bsp.h>
+// #include <termios.h>
+#include <stdio.h>
+#include <stdlib.h>
+// #include <rtems/termiostypes.h>
+#include <libchip/serial.h>
+#include <libchip/ns16550.h>
+#include <rtems/bspIo.h>
+#include <rtems/pci.h>
+#include "../../../shared/console_private.h"
+#define MAX_BOARDS 4
+ * Information saved from PCI scan
+typedef struct {
+  bool      found;
+  uint32_t  base;
+  uint8_t   irq;
+  uint8_t   bus;
+  uint8_t   slot;
+  int       ports;
+  uint32_t  clock;
+} port_instance_conf_t;
+ *  Register Access Routines
+static uint8_t pci_ns16550_get_register(uint32_t addr, uint8_t i)
+  uint8_t          val = 0;
+  volatile uint32_t *reg = (volatile uint32_t *)(addr + (i*4));
+  val = *reg;
+  /* printk( "RD(%p -> 0x%02x) ", reg, val ); */
+  return val;
+static void pci_ns16550_set_register(uint32_t addr, uint8_t i, uint8_t val)
+  /* printk( "WR(%p <- 0x%02x) ", reg, val ); */
+  *reg = val;
+void pci_uart_probe(void)
+  port_instance_conf_t  conf[MAX_BOARDS];
+  int                   boards = 0;
+  int                   b = 0;
+  console_tbl          *ports;
+  console_tbl          *port_p;
+  int                   bus;
+  int                   dev;
+  int                   fun;
+  int                   status;
+  int                   instance;
+  int                   i;
+  int                   total_ports = 0;
+  for ( b=0 ; b<MAX_BOARDS ; b++ ) {
+    conf[b].found = false;
+   *  Scan for Serial port boards
+  for ( instance=0 ; instance < MAX_BOARDS ; instance++ ) {
+    for ( i=0 ; pci_ns8250_ids[i].vendor != 0xffff ; i++ ) {
+      if ( pci_ns8250_ids[i].vendor == 0xffff ) {
+        break;
+      printk("Looking for 0x%04x:0x%04x\n",
+        pci_ns8250_ids[i].vendor,
+        pci_ns8250_ids[i].device);
+      status = pci_find_device(
+        pci_ns8250_ids[i].device,
+        instance,
+        &bus,
+        &dev,
+        &fun
+      if ( status == PCIB_ERR_SUCCESS ) {
+        boards++;
+        conf[instance].found = true;
+        conf[instance].clock =  pci_ns8250_ids[i].rclk;
+        conf[instance].ports = 1;
+        total_ports += conf[instance].ports;
+        break;
+    if ( status != PCIB_ERR_SUCCESS )
+      continue;
+    uint8_t  irq;
+    uint32_t base;
+    pci_read_config_byte( bus, dev, fun, PCI_INTERRUPT_LINE, &irq );
+    pci_read_config_dword( bus, dev, fun, PCI_BASE_ADDRESS_0, &base );
+    conf[instance].irq  = irq;
+    conf[instance].base = base;
+    printk(
+      "Found %s #%d at 0x%08x IRQ %d with %d clock\n",
+      pci_ns8250_ids[i].desc,
+      instance,
+      conf[instance].base,
+      conf[instance].irq,
+   *  Now allocate array of device structures and fill them in
+  int device_instance;
+  ports = calloc( total_ports, sizeof( console_tbl ) );
+  port_p = ports;
+  device_instance = 1;
+    if ( conf[b].found == false )
+      continue;
+    char name[32];
+    sprintf( name, "/dev/pcicom%d", device_instance++ );
+    port_p->sDeviceName   = strdup( name );
+    port_p->deviceType    = SERIAL_NS16550;
+    if ( conf[b].irq <= 15 ) {
+      port_p->pDeviceFns    = &ns16550_fns;
+    } else {
+      printk(
+        "%s IRQ=%d >= 16 requires APIC support, using polling\n",
+        name,
+        conf[b].irq <= 15
+      port_p->pDeviceFns    = &ns16550_fns_polled;
+    port_p->deviceProbe   = NULL;
+    port_p->pDeviceFlow   = NULL;
+    port_p->ulMargin      = 16;
+    port_p->ulHysteresis  = 8;
+    port_p->pDeviceParams = (void *) 9600;
+    port_p->ulCtrlPort1   = conf[b].base;
+    port_p->ulCtrlPort2   = 0;                   /* NA */
+    port_p->ulDataPort    = 0;                   /* NA */
+    port_p->getRegister   = pci_ns16550_get_register;
+    port_p->setRegister   = pci_ns16550_set_register;
+    port_p->getData       = NULL;                /* NA */
+    port_p->setData       = NULL;                /* NA */
+    port_p->ulClock       = conf[b].clock;
+    port_p->ulIntVector   = conf[b].irq;
+    port_p++;
+  }    /* end boards */
+   *  Register the devices
+  if ( boards )
+    console_register_devices( ports, total_ports );
+#endif
diff --git a/c/src/lib/libbsp/i386/pc386/include/bsp.h b/c/src/lib/libbsp/i386/pc386/include/bsp.h
index 21591f6..2fc922a 100644
--- a/c/src/lib/libbsp/i386/pc386/include/bsp.h
+++ b/c/src/lib/libbsp/i386/pc386/include/bsp.h
@@ -280,6 +280,10 @@ void C_dispatch_isr(int vector);
 void pc386_parse_console_arguments(void);
+ * Dynamically probe for PCI UARTS
+void pci_uart_probe(void);
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
index 26533ae..50afe18 100644
--- a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
+++ b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
@@ -111,6 +111,11 @@ static void bsp_start_default( void )
   bsp_pci_initialize_helper();
+   * Probe for UARTs on PCI. One of these may end up as the console.
+  pci_uart_probe();
    * Figure out where printk() and console IO is to be directed.
    * Do this after the PCI bus is initialized so we have a chance
    * for those devices to be added to the set in the console driver.
1.8.3.1
