[PATCH 10/17] pc386/startup/bspstart.c: Reformat and cleanup file header
Wed Mar 9 22:24:55 UTC 2016
 c/src/lib/libbsp/i386/pc386/startup/bspstart.c | 56 +++++++++++++-------------
 1 file changed, 27 insertions(+), 29 deletions(-)
diff --git a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
index 50afe18..5671a4b 100644
--- a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
+++ b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
@@ -1,32 +1,30 @@
-| This file contains the PC386 BSP startup package. It includes application,
-| board, and monitor specific initialization and configuration. The generic CPU
-| dependent initialization has been performed before this routine is invoked.
-| (C) Copyright 1997 -
-| - NavIST Group - Real-Time Distributed Systems and Industrial Automation
-| http://pandora.ist.utl.pt
-| Instituto Superior Tecnico * Lisboa * PORTUGAL
-| Disclaimer:
-| This file is provided "AS IS" without warranty of any kind, either
-| expressed or implied.
-| This code is based on:
-|   bspstart.c,v 1.8 1996/05/28 13:12:40 joel Exp - go32 BSP
-| With the following copyright notice:
-| *  COPYRIGHT (c) 1989-2008.
-| *  On-Line Applications Research Corporation (OAR).
-| *  The license and distribution terms for this file may be
-| *  found in the file LICENSE in this distribution or at
-| *  http://www.rtems.org/license/LICENSE.
+ * @file
+ * This file contains the PC386 BSP startup package. It includes application,
+ * board, and monitor specific initialization and configuration.
+ * This file was initially written by Joel Sherrill as part of the go32 BSP.
+ * It was subsequently adapted as part of the pc386 BSP by developers from
+ * the NavIST Group in 1997.
+ * COPYRIGHT (c) 1989-2008, 2016.
+ * On-Line Applications Research Corporation (OAR).
+ * (C) Copyright 1997 -
+ * - NavIST Group - Real-Time Distributed Systems and Industrial Automation
+ * Instituto Superior Tecnico * Lisboa * PORTUGAL (http://pandora.ist.utl.pt)
+ * NavISY Disclaimer:
+ * This file is provided "AS IS" without warranty of any kind, either
+ * expressed or implied.
 #include <bsp.h>
 #include <bsp/irq.h>
1.8.3.1
