[PATCH 01/14] cpuuse/cpuusagetop.c: Fix unused variable warning
Tue Mar 22 14:46:35 UTC 2016
The commit message doesn't cover all changes.
On 22/03/16 15:40, Joel Sherrill wrote:
>   cpukit/libmisc/cpuuse/cpuusagetop.c         | 1 -
>   cpukit/score/src/threadglobalconstruction.c | 3 +++
>   testsuites/sptests/Makefile.am              | 2 +-
>   testsuites/sptests/sp13/task1.c             | 9 +++++----
>   4 files changed, 9 insertions(+), 6 deletions(-)
> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
> index 9b92858..cf896e3 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagetop.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
> @@ -465,7 +465,6 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>       for (i = 0; i < data->task_count; i++)
>         Thread_Control*   thread = data->tasks[i];
> -      Timestamp_Control last;
>         Timestamp_Control usage;
>         Timestamp_Control current_usage;
> diff --git a/cpukit/score/src/threadglobalconstruction.c b/cpukit/score/src/threadglobalconstruction.c
> index 1e84124..bc96317 100644
> --- a/cpukit/score/src/threadglobalconstruction.c
> +++ b/cpukit/score/src/threadglobalconstruction.c
> @@ -62,5 +62,8 @@ void _Thread_Global_construction(
>     _Thread_Restart( executing, executing, entry );
>     _Thread_Enable_dispatch();
> +#ifdef __GNUC__
> +  __builtin_unreachable();
> +#endif
>     _Assert_Not_reached();
Maybe use new RTEMS_UNREACHABLE(). Maybe the RTEMS_UNREACHABLE() should
generate a fatal error in case RTEMS_DEBUG is defined to avoid the
undefined behaviour.
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index 43f3d82..53adfc1 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -65,7 +65,7 @@ _SUBDIRS += sptls03
>   _SUBDIRS += spcpucounter01
>   if HAS_CPLUSPLUS
>   _SUBDIRS += spglobalcon01
> -_SUBDIRS += sptls02
> +## _SUBDIRS += sptls02
>   endif
>   _SUBDIRS += sptls01
>   _SUBDIRS += spintrcritical20
Conflict with later patch?
> diff --git a/testsuites/sptests/sp13/task1.c b/testsuites/sptests/sp13/task1.c
> index e104e8d..58859c0 100644
> --- a/testsuites/sptests/sp13/task1.c
> +++ b/testsuites/sptests/sp13/task1.c
> @@ -352,10 +352,11 @@ rtems_test_pause();
>      for (cp = (big_receive_buffer + size);
>           cp < (big_receive_buffer + sizeof(big_receive_buffer));
> -        cp++)
> -    if (*cp != 'Z') {
> -      puts("TA1 - exact size overrun match failed");
> -      rtems_test_exit(1);
> +        cp++) {
> +      if (*cp != 'Z') {
> +        puts("TA1 - exact size overrun match failed");
> +        rtems_test_exit(1);
>       /* all done with this one; delete it */
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
