[PATCH 01/14] cpuuse/cpuusagetop.c: Fix unused variable warning
Joel Sherrill
joel at rtems.org
Tue Mar 22 15:21:05 UTC 2016
I don't know how these extra pieces got in that patch. :(
I will remove the pieces other than cpuusagetop.c.
For threadglobalconstruction.c, I am switching to just RTEMS_UNREACHABLE()
in place of this:
#ifdef __GNUC__
__builtin_unreachable();
#endif
_Assert_Not_reached();
I will send a new series of patches once the test builds complete.
On Tue, Mar 22, 2016 at 9:46 AM, Sebastian Huber <
> The commit message doesn't cover all changes.
> On 22/03/16 15:40, Joel Sherrill wrote:
>> cpukit/libmisc/cpuuse/cpuusagetop.c | 1 -
>> cpukit/score/src/threadglobalconstruction.c | 3 +++
>> testsuites/sptests/Makefile.am | 2 +-
>> testsuites/sptests/sp13/task1.c | 9 +++++----
>> 4 files changed, 9 insertions(+), 6 deletions(-)
>> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c
>> b/cpukit/libmisc/cpuuse/cpuusagetop.c
>> index 9b92858..cf896e3 100644
>> --- a/cpukit/libmisc/cpuuse/cpuusagetop.c
>> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
>> @@ -465,7 +465,6 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>> for (i = 0; i < data->task_count; i++)
>> Thread_Control* thread = data->tasks[i];
>> - Timestamp_Control last;
>> Timestamp_Control usage;
>> Timestamp_Control current_usage;
>> diff --git a/cpukit/score/src/threadglobalconstruction.c
>> b/cpukit/score/src/threadglobalconstruction.c
>> index 1e84124..bc96317 100644
>> --- a/cpukit/score/src/threadglobalconstruction.c
>> +++ b/cpukit/score/src/threadglobalconstruction.c
>> @@ -62,5 +62,8 @@ void _Thread_Global_construction(
>> _Thread_Restart( executing, executing, entry );
>> _Thread_Enable_dispatch();
>> +#ifdef __GNUC__
>> + __builtin_unreachable();
>> +#endif
> Maybe use new RTEMS_UNREACHABLE(). Maybe the RTEMS_UNREACHABLE() should
> generate a fatal error in case RTEMS_DEBUG is defined to avoid the
> undefined behaviour.
> diff --git a/testsuites/sptests/Makefile.am
>> b/testsuites/sptests/Makefile.am
>> index 43f3d82..53adfc1 100644
>> --- a/testsuites/sptests/Makefile.am
>> +++ b/testsuites/sptests/Makefile.am
>> @@ -65,7 +65,7 @@ _SUBDIRS += sptls03
>> _SUBDIRS += spcpucounter01
>> if HAS_CPLUSPLUS
>> _SUBDIRS += spglobalcon01
>> -_SUBDIRS += sptls02
>> +## _SUBDIRS += sptls02
>> endif
>> _SUBDIRS += sptls01
>> _SUBDIRS += spintrcritical20
> Conflict with later patch?
> diff --git a/testsuites/sptests/sp13/task1.c
>> b/testsuites/sptests/sp13/task1.c
>> index e104e8d..58859c0 100644
>> --- a/testsuites/sptests/sp13/task1.c
>> +++ b/testsuites/sptests/sp13/task1.c
>> @@ -352,10 +352,11 @@ rtems_test_pause();
>> for (cp = (big_receive_buffer + size);
>> cp < (big_receive_buffer + sizeof(big_receive_buffer));
>> - cp++)
>> - if (*cp != 'Z') {
>> - puts("TA1 - exact size overrun match failed");
>> - rtems_test_exit(1);
>> + cp++) {
>> + if (*cp != 'Z') {
>> + puts("TA1 - exact size overrun match failed");
>> + rtems_test_exit(1);
>> /* all done with this one; delete it */
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160322/952391a7/attachment.html>
