Participation in GSoC 2016
Deval Shah deval.maker at gmail.com
Wed Mar 23 13:03:47 UTC 2016
On Tue, Mar 22, 2016 at 10:04 PM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Hi Deval,
> Your proposal looks good. I would suggest adding a step where you build a
> known BSP with BSD lib support. It will help you become familiar with the
> development process.
Thanks for the suggestion, Alan. I will be adding this to my proposal.
Also, which BSP would you recommend that I pick up ? Is there any list
of currently added BSPs from which I can choose?
> You should also address which Raspberry Pi model you will support. Now that
> there are so many Raspberry Pi models, it might make the project more
> complicated:
> Original raspberry Pi Model A & A+: a single built in USB port in the
> BCM2835 CPU. No ethernet or USB hub.
> Raspberry Pi Model B & B+: USB hub and Ethernet in LAN9512 chip.
> Raspberry Pi 2 Model B: USB hub and Ethernet in LAN9514 chip.
> Raspberry Pi 3 Model B:  I would not worry about this one yet.
> Raspberry Pi Zero: A single USB OTG port , no ethernet or USB hub.
> I would pick one of them and get it working before seeing if another model
> could be supported.
> If the Raspberry Pi 1/B+ and 2/B Hubs are functionally the same ( LAN9512
> vs. LAN9514 ), this would support the widest range of devices out there.
I was also thinking for that. I have a Raspberry PI 1/B+ and a
majority of users have either 1/B+ or 2/B. Probably we can start with
1/B+ and then enable the other models.
> If you have time, I would love to see USB support for the BCM2835 on the Pi
> Model A+ and especially the Pi Zero.
Sure, I had left some buffer time in my proposal, probably if things
goes as per plan that time can be used for USB support for the
BCM2835.
> Thanks,
> Alan
> On Tue, Mar 22, 2016 at 8:52 AM, Deval Shah <deval.maker at gmail.com> wrote:
>> Hello,
>> I have updated my draft proposal and shared on the tracking page. I'm
>> sharing it here as well. https://goo.gl/QQiAf6
>> Sorry, I was busy with my Mid-Semester exams, could not update earlier.
>> Since this is a draft proposal, it may not be completely polished yet.
>> I'd appreciate any comments on it, especially regarding the project
>> description
>> and timeline.
>> Thank you.
>> Regards,
>> Deval Shah
>> On Fri, Mar 11, 2016 at 11:02 PM, Deval Shah <deval.maker at gmail.com>
>> wrote:
>> > On Fri, Mar 11, 2016 at 8:33 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>> >> On Fri, Mar 11, 2016 at 8:19 AM, Deval Shah <deval.maker at gmail.com>
>> >> wrote:
>> >>> Hello everyone!
>> >>> I went through the links and blogs of the SD card and USB/Ethernet
>> >>> project for Raspberry PI. I would like to work for the USB/Ethernet
>> >>> support project.
>> >>> I have prepared a draft of the timeline as follows:
>> >>> Acceptance Waiting Period:
>> >>> Understanding previous year's GSOC work
>> >>> First Half:
>> >>> completing USB support for RPI
>> >>> Testing USB and add drivers for HIDs like Mouse and Keyboard
>> >>> Second Half:
>> >>> Adding Ethernet Support
>> >>> Testing (ARP, PING, DHCP, FTP, TFTP)
>> >>> Adding support for lwIP (since it is already ported to BBB, this
>> >>> should not take more time)
>> >> Timeline seems good. Is the USB support available from freebsd for the
>> >> libbsd codebase?
>> > Yes. libbsd has support for USB.
>> > Last year issues were in porting the driver (
>> > http://gtament-rtems.blogspot.in/2015/06/my-progress-report.html ).
>> >>> If we have wifi support in RTEMS, can support of a USB wifi module be
>> >>> added to the project?
>> >> I haven't seen any one using wifi yet.
>> >>> I'd really appreciate any feedback on my deliverables, especially
>> >>> regarding the feasibility of doing it in this time frame. If there is
>> >>> anything I may have missed out or anything else I should consider as a
>> >>> part of this, I'd be really glad if someone could point that out, so
>> >>> as to increase my chances of selection.
>> >>> A quick question: How can I add my name to the tracking list @
>> >>> https://devel.rtems.org/wiki/GSoC/2016 ?
>> >> You need to register an account to edit the page through link at the
>> >> bottom.
>> >> Okay, Thank you.
>> >>> Deval Shah
>> >>> On Tue, Mar 1, 2016 at 3:07 AM, André Marques
>> >>> <andre.lousa.marques at gmail.com> wrote:
>> >>>> Hello Jan and Deval,
>> >>>> Às 20:24 de 29-02-2016, Jan Sommer escreveu:
>> >>>>> Hi,
>> >>>>> If you take a look here:
>> >>>>> https://devel.rtems.org/wiki/GSoC/2015#StudentsSummerofCodeTrackingTable you
>> >>>>> can find the links to the reports and repositories of the previous
>> >>>>> GSoC.
>> >>>>> Yurii Shevtsov was doing the work on the Ethernet/USB part for the
>> >>>>> pi.
>> >>>>> Andre Marques worked on the SPI and SD-Card driver.
>> >>>> I have updated a bit the Raspberry Open Projects page with the state
>> >>>> of the
>> >>>> low level peripherals project, and provided links to the state of
>> >>>> each of
>> >>>> the other projects (the wiki pages of the students working on them
>> >>>> last
>> >>>> year, which also include their blogs and githubs).
>> >>>> https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveRaspberryPiBSP
>> >>>>  The other 3 raspberry projects I do not know exactly their current
>> >>>> state,
>> >>>> but they already have some work done (just not in the RTEMS tree
>> >>>> yet).
>> >>>> It seems that only GPIO, I2C and SPI were merged last year.
>> >>>>> Cheers,
>> >>>>>     Jan
>> >>>>> Am Tuesday 01 March 2016, 01:15:24 schrieb Deval Shah:
>> >>>>>> It looks like there are more useful things in pipeline before
>> >>>>>> raspberry
>> >>>>>> pi
>> >>>>>> cam support.
>> >>>>>> Can anybody give me pointers/links to refer for porting ethernet
>> >>>>>> support
>> >>>>>> and SD card support?
>> >>>> For the last year efforts on the SD card support you can refer to:
>> >>>> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
>> >>>>>> On Thursday 18 February 2016, soja-lists at aries.uberspace.de <
>> >>>>>> soja-lists at aries.uberspace.de> wrote:
>> >>>>>>> Am 2016-02-18 01:26, schrieb Joel Sherrill:
>> >>>>>>>> On Feb 17, 2016 6:17 PM, "André Marques"
>> >>>>>>>> wrote:
>> >>>>>>>> Was i2c fully delivered for the new driver framework? I don't
>> >>>>>>>> recall
>> >>>>>>>>> off-hand.
>> >>>>>>>>> Yes the i2c driver for the Pi uses the new (linux-based) i2c
>> >>>>>>>>> framework.
>> >>>>>>>> 10-bit addressing is untested because I had no compatible slave
>> >>>>>>>> device.
>> >>>>>>>>> A detailed report of my last GSOC can be found here:
>> >>>>>>>>> SD card support was started but not completed last year, so it
>> >>>>>>>>> may be
>> >>>>>>>> included on a potential Raspberry project. I can help with that
>> >>>>>>>> if
>> >>>>>>>> needed.
>> >>>>>>>> Andres.. Thanks for speaking up. Can you update the project page
>> >>>>>>>> and
>> >>>>>>>> link
>> >>>>>>>> to your blog?
>> >>>>>>>> What else do you think needs find on the Pi and Pi2?
>> >>>>>>> Last year there was a GSoC to add ethernet support for the
>> >>>>>>> raspberry pi
>> >>>>>>> via rtems-libbsd, but I think it was never finished.
>> >>>>>>> Maybe that could be started again?
>> >>>>>>> I haven't researched it yet to know if it is feasible but I am
>> >>>>>>> curious
>> >>>>>>> if
>> >>>>>>>> the Arduino HW libraries have a clean porting layer which could
>> >>>>>>>> provide
>> >>>>>>>> support for a lot of i2c devices. Is this a wikd goose chase or
>> >>>>>>>> of
>> >>>>>>>> potential value?
>> >>>>>>> Sounds like an interesting idea, but isn't Arduino written in C++?
>> >>>>>>> Best regards,
>> >>>>>>>     Jan
>> >>>>>>>>> I very much look forward for any pointers on this.
>> >>>>>>>>>>> I am eager to work for RTEMS organization because I believe my
>> >>>>>>>>>>> skill
>> >>>>>>>>>>> set is best suited for this.
>> >>>>>>>>>>> Thanking you,
>> >>>>>>>>>>> Deval Shah
>> >>>>>>>>>>> _______________________________________________
>> >>>>>>>>>>> devel mailing list
>> >>>>>>>>>>> devel at rtems.org
>> >>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>> >>>>>>>>> --André Marques
>> >>>>>>>>> devel mailing list
>> >>>>>>>>> devel at rtems.org
>> >>>>>>>> devel mailing list
>> >>>>>>>> devel at rtems.org
>> >>>>>>> devel mailing list
>> >>>>>>> devel at rtems.org
>> >>>>> devel mailing list
>> >>>>> devel at rtems.org
>> >>>> --André Marques
>> devel mailing list
>> devel at rtems.org
