Participation in GSoC 2016
Deval Shah deval.maker at gmail.com
Thu Mar 24 21:36:15 UTC 2016
Great ! I will add this to my application. Parallely I was looking for
some other BSP like this. Looks like last year André added support for
SD card by adding the SDHCI and MMC/SD bus drivers from libBSD
successfully (https://devel.rtems.org/wiki/GSoC/2015/Final_Report#AndreMarques:RaspberryPiLowLevelPeripheralsandSDCard).
I will build anyone of them (arm/realview_pbx_a9_qemu or SD card) in
my acceptance waiting period and get familiarised with the build
process.
I think from my side my proposal is ready. You can have a look at
that. Kindly suggest if anything alse is missing.
On Thu, Mar 24, 2016 at 7:13 PM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> The Pi 1/B+ would be a good model to start the USB development with.
> I have actually not built the BSD lib myself. But I think this is the place
> to start:
> https://git.rtems.org/rtems-libbsd/tree/libbsd.txt
> https://git.rtems.org/rtems-libbsd/tree/README.waf
> Looks like the arm/realview_pbx_a9_qemu BSP is the one use.
> I have run some of the SMP examples on qemu with the
> arm/realview_pbx_a9_qemu_smp BSP and it worked well for me.
> Alan
> On Wed, Mar 23, 2016 at 9:03 AM, Deval Shah <deval.maker at gmail.com> wrote:
>> On Tue, Mar 22, 2016 at 10:04 PM, Alan Cudmore <alan.cudmore at gmail.com>
>> wrote:
>> > Hi Deval,
>> > Your proposal looks good. I would suggest adding a step where you build
>> > a
>> > known BSP with BSD lib support. It will help you become familiar with
>> > the
>> > development process.
>> Thanks for the suggestion, Alan. I will be adding this to my proposal.
>> Also, which BSP would you recommend that I pick up ? Is there any list
>> of currently added BSPs from which I can choose?
>> > You should also address which Raspberry Pi model you will support. Now
>> > that
>> > there are so many Raspberry Pi models, it might make the project more
>> > complicated:
>> > Original raspberry Pi Model A & A+: a single built in USB port in the
>> > BCM2835 CPU. No ethernet or USB hub.
>> > Raspberry Pi Model B & B+: USB hub and Ethernet in LAN9512 chip.
>> > Raspberry Pi 2 Model B: USB hub and Ethernet in LAN9514 chip.
>> > Raspberry Pi 3 Model B:  I would not worry about this one yet.
>> > Raspberry Pi Zero: A single USB OTG port , no ethernet or USB hub.
>> > I would pick one of them and get it working before seeing if another
>> > model
>> > could be supported.
>> > If the Raspberry Pi 1/B+ and 2/B Hubs are functionally the same (
>> > LAN9512
>> > vs. LAN9514 ), this would support the widest range of devices out there.
>> I was also thinking for that. I have a Raspberry PI 1/B+ and a
>> majority of users have either 1/B+ or 2/B. Probably we can start with
>> 1/B+ and then enable the other models.
>> > If you have time, I would love to see USB support for the BCM2835 on the
>> > Pi
>> > Model A+ and especially the Pi Zero.
>> Sure, I had left some buffer time in my proposal, probably if things
>> goes as per plan that time can be used for USB support for the
>> BCM2835.
>> > Thanks,
>> > Alan
>> > On Tue, Mar 22, 2016 at 8:52 AM, Deval Shah <deval.maker at gmail.com>
>> > wrote:
>> >> Hello,
>> >> I have updated my draft proposal and shared on the tracking page. I'm
>> >> sharing it here as well. https://goo.gl/QQiAf6
>> >> Sorry, I was busy with my Mid-Semester exams, could not update earlier.
>> >> Since this is a draft proposal, it may not be completely polished yet.
>> >> I'd appreciate any comments on it, especially regarding the project
>> >> description
>> >> and timeline.
>> >> Thank you.
>> >> Regards,
>> >> Deval Shah
>> >> On Fri, Mar 11, 2016 at 11:02 PM, Deval Shah <deval.maker at gmail.com>
>> >> wrote:
>> >> > On Fri, Mar 11, 2016 at 8:33 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>> >> >> On Fri, Mar 11, 2016 at 8:19 AM, Deval Shah <deval.maker at gmail.com>
>> >> >> wrote:
>> >> >>> Hello everyone!
>> >> >>> I went through the links and blogs of the SD card and USB/Ethernet
>> >> >>> project for Raspberry PI. I would like to work for the USB/Ethernet
>> >> >>> support project.
>> >> >>> I have prepared a draft of the timeline as follows:
>> >> >>> Acceptance Waiting Period:
>> >> >>> Understanding previous year's GSOC work
>> >> >>> First Half:
>> >> >>> completing USB support for RPI
>> >> >>> Testing USB and add drivers for HIDs like Mouse and Keyboard
>> >> >>> Second Half:
>> >> >>> Adding Ethernet Support
>> >> >>> Testing (ARP, PING, DHCP, FTP, TFTP)
>> >> >>> Adding support for lwIP (since it is already ported to BBB, this
>> >> >>> should not take more time)
>> >> >> Timeline seems good. Is the USB support available from freebsd for
>> >> >> the
>> >> >> libbsd codebase?
>> >> > Yes. libbsd has support for USB.
>> >> > Last year issues were in porting the driver (
>> >> > http://gtament-rtems.blogspot.in/2015/06/my-progress-report.html ).
>> >> >>> If we have wifi support in RTEMS, can support of a USB wifi module
>> >> >>> be
>> >> >>> added to the project?
>> >> >> I haven't seen any one using wifi yet.
>> >> >>> I'd really appreciate any feedback on my deliverables, especially
>> >> >>> regarding the feasibility of doing it in this time frame. If there
>> >> >>> is
>> >> >>> anything I may have missed out or anything else I should consider
>> >> >>> as a
>> >> >>> part of this, I'd be really glad if someone could point that out,
>> >> >>> so
>> >> >>> as to increase my chances of selection.
>> >> >>> A quick question: How can I add my name to the tracking list @
>> >> >>> https://devel.rtems.org/wiki/GSoC/2016 ?
>> >> >> You need to register an account to edit the page through link at the
>> >> >> bottom.
>> >> >> Okay, Thank you.
>> >> >>> Deval Shah
>> >> >>> On Tue, Mar 1, 2016 at 3:07 AM, André Marques
>> >> >>> <andre.lousa.marques at gmail.com> wrote:
>> >> >>>> Hello Jan and Deval,
>> >> >>>> Às 20:24 de 29-02-2016, Jan Sommer escreveu:
>> >> >>>>> Hi,
>> >> >>>>> If you take a look here:
>> >> >>>>> https://devel.rtems.org/wiki/GSoC/2015#StudentsSummerofCodeTrackingTable you
>> >> >>>>> can find the links to the reports and repositories of the
>> >> >>>>> previous
>> >> >>>>> GSoC.
>> >> >>>>> Yurii Shevtsov was doing the work on the Ethernet/USB part for
>> >> >>>>> the
>> >> >>>>> pi.
>> >> >>>>> Andre Marques worked on the SPI and SD-Card driver.
>> >> >>>> I have updated a bit the Raspberry Open Projects page with the
>> >> >>>> state
>> >> >>>> of the
>> >> >>>> low level peripherals project, and provided links to the state of
>> >> >>>> each of
>> >> >>>> the other projects (the wiki pages of the students working on them
>> >> >>>> last
>> >> >>>> year, which also include their blogs and githubs).
>> >> >>>> https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveRaspberryPiBSP
>> >> >>>>  The other 3 raspberry projects I do not know exactly their
>> >> >>>> current
>> >> >>>> state,
>> >> >>>> but they already have some work done (just not in the RTEMS tree
>> >> >>>> yet).
>> >> >>>> It seems that only GPIO, I2C and SPI were merged last year.
>> >> >>>>> Cheers,
>> >> >>>>>     Jan
>> >> >>>>> Am Tuesday 01 March 2016, 01:15:24 schrieb Deval Shah:
>> >> >>>>>> It looks like there are more useful things in pipeline before
>> >> >>>>>> raspberry
>> >> >>>>>> pi
>> >> >>>>>> cam support.
>> >> >>>>>> Can anybody give me pointers/links to refer for porting ethernet
>> >> >>>>>> support
>> >> >>>>>> and SD card support?
>> >> >>>> For the last year efforts on the SD card support you can refer to:
>> >> >>>> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
>> >> >>>>>> On Thursday 18 February 2016, soja-lists at aries.uberspace.de <
>> >> >>>>>> soja-lists at aries.uberspace.de> wrote:
>> >> >>>>>>> Am 2016-02-18 01:26, schrieb Joel Sherrill:
>> >> >>>>>>>> On Feb 17, 2016 6:17 PM, "André Marques"
>> >> >>>>>>>> wrote:
>> >> >>>>>>>> Was i2c fully delivered for the new driver framework? I don't
>> >> >>>>>>>> recall
>> >> >>>>>>>>> off-hand.
>> >> >>>>>>>>> Yes the i2c driver for the Pi uses the new (linux-based) i2c
>> >> >>>>>>>>> framework.
>> >> >>>>>>>> 10-bit addressing is untested because I had no compatible
>> >> >>>>>>>> slave
>> >> >>>>>>>> device.
>> >> >>>>>>>>> A detailed report of my last GSOC can be found here:
>> >> >>>>>>>>> SD card support was started but not completed last year, so
>> >> >>>>>>>>> it
>> >> >>>>>>>>> may be
>> >> >>>>>>>> included on a potential Raspberry project. I can help with
>> >> >>>>>>>> that
>> >> >>>>>>>> if
>> >> >>>>>>>> needed.
>> >> >>>>>>>> Andres.. Thanks for speaking up. Can you update the project
>> >> >>>>>>>> page
>> >> >>>>>>>> and
>> >> >>>>>>>> link
>> >> >>>>>>>> to your blog?
>> >> >>>>>>>> What else do you think needs find on the Pi and Pi2?
>> >> >>>>>>> Last year there was a GSoC to add ethernet support for the
>> >> >>>>>>> raspberry pi
>> >> >>>>>>> via rtems-libbsd, but I think it was never finished.
>> >> >>>>>>> Maybe that could be started again?
>> >> >>>>>>> I haven't researched it yet to know if it is feasible but I am
>> >> >>>>>>> curious
>> >> >>>>>>> if
>> >> >>>>>>>> the Arduino HW libraries have a clean porting layer which
>> >> >>>>>>>> could
>> >> >>>>>>>> provide
>> >> >>>>>>>> support for a lot of i2c devices. Is this a wikd goose chase
>> >> >>>>>>>> or
>> >> >>>>>>>> of
>> >> >>>>>>>> potential value?
>> >> >>>>>>> Sounds like an interesting idea, but isn't Arduino written in
>> >> >>>>>>> C++?
>> >> >>>>>>> Best regards,
>> >> >>>>>>>     Jan
>> >> >>>>>>>>> I very much look forward for any pointers on this.
>> >> >>>>>>>>>>> I am eager to work for RTEMS organization because I believe
>> >> >>>>>>>>>>> my
>> >> >>>>>>>>>>> skill
>> >> >>>>>>>>>>> set is best suited for this.
>> >> >>>>>>>>>>> Thanking you,
>> >> >>>>>>>>>>> Deval Shah
>> >> >>>>>>>>>>> _______________________________________________
>> >> >>>>>>>>>>> devel mailing list
>> >> >>>>>>>>>>> devel at rtems.org
>> >> >>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>> >> >>>>>>>>> --André Marques
>> >> >>>>>>>>> devel mailing list
>> >> >>>>>>>>> devel at rtems.org
>> >> >>>>>>>> devel mailing list
>> >> >>>>>>>> devel at rtems.org
>> >> >>>>>>> devel mailing list
>> >> >>>>>>> devel at rtems.org
>> >> >>>>> devel mailing list
>> >> >>>>> devel at rtems.org
>> >> >>>> --André Marques
>> >> devel mailing list
>> >> devel at rtems.org
