BBB GSoC Projects was Re: Gsoc 2016 project proposal
Wed Mar 2 19:56:54 UTC 2016
On Wed, Mar 2, 2016 at 1:41 PM, punit vara <punitvara at gmail.com> wrote:
> Yes I have checked previous year work of ketul . He has done ADC and GPIO
> BSP . It seems SPI,USB BSP need to be developed as I have checked rtems.git
> and I am not sure about I2C .I asked last year student Ketul .According to
> him , I2c is also need to be modified. I tried to contact Ben but he is
> unreachable on mailing list :-(
Let me reach out to Ketul and see if a private ping helps.
Start with the assumption that USB needs work. That involves the
rtems-libbsd tree and
there is likely code to import from FreeBSD that will help a lot.
SPI and i2c are close to one another in my understanding. Likely Ketul is
referring to changes
in the RTEMS i2c interfaces.
My recollection is that the NIC had performance issues based on the version
of U-Boot
used. There was some traffic at the end of GSoC about this. I don't know if
it was
ever resolved.  But the NIC should work. Maybe worth benchmarking.
--joel
On Thu, Mar 3, 2016 at 12:57 AM, Joel Sherrill <joel at rtems.org> wrote:
>> On Wed, Mar 2, 2016 at 1:24 PM, Hesham Almatary <heshamelmatary at gmail.com
>> > wrote:
>>> Hi Punit,
>>> You can have a look at the open projects here [1] and find one or more
>>> that match your experience/interests.
>>> [1] https://devel.rtems.org/wiki/Developer/OpenProjects
>> I have added Ben Gras. He knows more about the BBB than anyone. I am
>> unsure what is left
>> to do. Have you compared the status of last year's projects versus the
>> git repository?
>> --joel
>>> Regards,
>>> On Wed, Mar 2, 2016 at 7:14 PM, punit vara <punitvara at gmail.com> wrote:
>>> >  I have asked for BBB BSP proposal before but I haven't found any good
>>> > response from someone. What are the projects you are going to mentor
>>> @joel ?
>>> > Would anyone please suggest me to pick any other project ?
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>>> Hesham
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160302/d81baef8/attachment-0002.html>
