AW: libbsd requires rtems version number in path?
Thomas Dörfler
Thomas.Doerfler at embedded-brains.de
Tue Mar 15 21:17:47 UTC 2016
Alternatively you can add a --rtems-version=4.11 to the waf command line...
Von meinem Samsung Gerät gesendet.
-------- Ursprüngliche Nachricht --------
Von: Gedare Bloom <gedare at rtems.org>
Datum: 15.03.2016 22:07 (GMT+01:00)
An: devel at rtems.org
Betreff: libbsd requires rtems version number in path?
I found out just now that to 'waf configure' rtems-libbsd requires
that the installed rtems is in a path with the version number
designated somehow, e.g. ${HOME}/install/4.12. I guess this is by
design, and most of our quick start guides should provide for this,
but I don't know that I've seen this "requirement" listed anywhere. It
was a bit of a surprise.
As I had not used the version number for an install, I made a symlink
with 4.12 in the name to point to my prefix to "trick" the configure.
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160315/151f238d/attachment-0002.html>
