[PATCH 01/14] cpuuse/cpuusagetop.c: Fix unused variable warning
Tue Mar 22 15:21:54 UTC 2016
Please commit your RTEMS_UNREACHABLE so I can use it. ::)
--joel
On Tue, Mar 22, 2016 at 10:21 AM, Joel Sherrill <joel at rtems.org> wrote:
> I don't know how these extra pieces got in that patch. :(
> I will remove the pieces other than cpuusagetop.c.
> For threadglobalconstruction.c, I am switching to just RTEMS_UNREACHABLE()
> in place of this:
> #ifdef __GNUC__
>   __builtin_unreachable();
> #endif
>   _Assert_Not_reached();
> I will send a new series of patches once the test builds complete.
> On Tue, Mar 22, 2016 at 9:46 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> The commit message doesn't cover all changes.
>> On 22/03/16 15:40, Joel Sherrill wrote:
>>>   cpukit/libmisc/cpuuse/cpuusagetop.c         | 1 -
>>>   cpukit/score/src/threadglobalconstruction.c | 3 +++
>>>   testsuites/sptests/Makefile.am              | 2 +-
>>>   testsuites/sptests/sp13/task1.c             | 9 +++++----
>>>   4 files changed, 9 insertions(+), 6 deletions(-)
>>> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c
>>> b/cpukit/libmisc/cpuuse/cpuusagetop.c
>>> index 9b92858..cf896e3 100644
>>> --- a/cpukit/libmisc/cpuuse/cpuusagetop.c
>>> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
>>> @@ -465,7 +465,6 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
>>>       for (i = 0; i < data->task_count; i++)
>>>         Thread_Control*   thread = data->tasks[i];
>>> -      Timestamp_Control last;
>>>         Timestamp_Control usage;
>>>         Timestamp_Control current_usage;
>>>   diff --git a/cpukit/score/src/threadglobalconstruction.c
>>> b/cpukit/score/src/threadglobalconstruction.c
>>> index 1e84124..bc96317 100644
>>> --- a/cpukit/score/src/threadglobalconstruction.c
>>> +++ b/cpukit/score/src/threadglobalconstruction.c
>>> @@ -62,5 +62,8 @@ void _Thread_Global_construction(
>>>     _Thread_Restart( executing, executing, entry );
>>>     _Thread_Enable_dispatch();
>>>   +#ifdef __GNUC__
>>> +  __builtin_unreachable();
>>> +#endif
>> Maybe use new RTEMS_UNREACHABLE(). Maybe the RTEMS_UNREACHABLE() should
>> generate a fatal error in case RTEMS_DEBUG is defined to avoid the
>> undefined behaviour.
>> diff --git a/testsuites/sptests/Makefile.am
>>> b/testsuites/sptests/Makefile.am
>>> index 43f3d82..53adfc1 100644
>>> --- a/testsuites/sptests/Makefile.am
>>> +++ b/testsuites/sptests/Makefile.am
>>> @@ -65,7 +65,7 @@ _SUBDIRS += sptls03
>>>   _SUBDIRS += spcpucounter01
>>>   if HAS_CPLUSPLUS
>>>   _SUBDIRS += spglobalcon01
>>> -_SUBDIRS += sptls02
>>> +## _SUBDIRS += sptls02
>>>   endif
>>>   _SUBDIRS += sptls01
>>>   _SUBDIRS += spintrcritical20
>> Conflict with later patch?
>> diff --git a/testsuites/sptests/sp13/task1.c
>>> b/testsuites/sptests/sp13/task1.c
>>> index e104e8d..58859c0 100644
>>> --- a/testsuites/sptests/sp13/task1.c
>>> +++ b/testsuites/sptests/sp13/task1.c
>>> @@ -352,10 +352,11 @@ rtems_test_pause();
>>>        for (cp = (big_receive_buffer + size);
>>>           cp < (big_receive_buffer + sizeof(big_receive_buffer));
>>> -        cp++)
>>> -    if (*cp != 'Z') {
>>> -      puts("TA1 - exact size overrun match failed");
>>> -      rtems_test_exit(1);
>>> +        cp++) {
>>> +      if (*cp != 'Z') {
>>> +        puts("TA1 - exact size overrun match failed");
>>> +        rtems_test_exit(1);
>>>         /* all done with this one; delete it */
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160322/c37cea9a/attachment-0002.html>
