Participation in GSoC 2016
Alan Cudmore alan.cudmore at gmail.com
Thu Mar 24 13:43:34 UTC 2016
The Pi 1/B+ would be a good model to start the USB development with.
I have actually not built the BSD lib myself. But I think this is the place
to start:
https://git.rtems.org/rtems-libbsd/tree/libbsd.txt
https://git.rtems.org/rtems-libbsd/tree/README.waf
Looks like the arm/realview_pbx_a9_qemu BSP is the one use.
I have run some of the SMP examples on qemu with the
arm/realview_pbx_a9_qemu_smp BSP and it worked well for me.
Alan
On Wed, Mar 23, 2016 at 9:03 AM, Deval Shah <deval.maker at gmail.com> wrote:
> On Tue, Mar 22, 2016 at 10:04 PM, Alan Cudmore <alan.cudmore at gmail.com>
> wrote:
> > Hi Deval,
> > Your proposal looks good. I would suggest adding a step where you build a
> > known BSP with BSD lib support. It will help you become familiar with the
> > development process.
> Thanks for the suggestion, Alan. I will be adding this to my proposal.
> Also, which BSP would you recommend that I pick up ? Is there any list
> of currently added BSPs from which I can choose?
> > You should also address which Raspberry Pi model you will support. Now
> that
> > there are so many Raspberry Pi models, it might make the project more
> > complicated:
> > Original raspberry Pi Model A & A+: a single built in USB port in the
> > BCM2835 CPU. No ethernet or USB hub.
> > Raspberry Pi Model B & B+: USB hub and Ethernet in LAN9512 chip.
> > Raspberry Pi 2 Model B: USB hub and Ethernet in LAN9514 chip.
> > Raspberry Pi 3 Model B:  I would not worry about this one yet.
> > Raspberry Pi Zero: A single USB OTG port , no ethernet or USB hub.
> > I would pick one of them and get it working before seeing if another
> model
> > could be supported.
> > If the Raspberry Pi 1/B+ and 2/B Hubs are functionally the same ( LAN9512
> > vs. LAN9514 ), this would support the widest range of devices out there.
> I was also thinking for that. I have a Raspberry PI 1/B+ and a
> majority of users have either 1/B+ or 2/B. Probably we can start with
> 1/B+ and then enable the other models.
> > If you have time, I would love to see USB support for the BCM2835 on the
> Pi
> > Model A+ and especially the Pi Zero.
> Sure, I had left some buffer time in my proposal, probably if things
> goes as per plan that time can be used for USB support for the
> BCM2835.
> > Thanks,
> > Alan
> > On Tue, Mar 22, 2016 at 8:52 AM, Deval Shah <deval.maker at gmail.com>
> wrote:
> >> Hello,
> >> I have updated my draft proposal and shared on the tracking page. I'm
> >> sharing it here as well. https://goo.gl/QQiAf6
> >> Sorry, I was busy with my Mid-Semester exams, could not update earlier.
> >> Since this is a draft proposal, it may not be completely polished yet.
> >> I'd appreciate any comments on it, especially regarding the project
> >> description
> >> and timeline.
> >> Thank you.
> >> Regards,
> >> Deval Shah
> >> On Fri, Mar 11, 2016 at 11:02 PM, Deval Shah <deval.maker at gmail.com>
> >> wrote:
> >> > On Fri, Mar 11, 2016 at 8:33 PM, Gedare Bloom <gedare at gwu.edu> wrote:
> >> >> On Fri, Mar 11, 2016 at 8:19 AM, Deval Shah <deval.maker at gmail.com>
> >> >> wrote:
> >> >>> Hello everyone!
> >> >>> I went through the links and blogs of the SD card and USB/Ethernet
> >> >>> project for Raspberry PI. I would like to work for the USB/Ethernet
> >> >>> support project.
> >> >>> I have prepared a draft of the timeline as follows:
> >> >>> Acceptance Waiting Period:
> >> >>> Understanding previous year's GSOC work
> >> >>> First Half:
> >> >>> completing USB support for RPI
> >> >>> Testing USB and add drivers for HIDs like Mouse and Keyboard
> >> >>> Second Half:
> >> >>> Adding Ethernet Support
> >> >>> Testing (ARP, PING, DHCP, FTP, TFTP)
> >> >>> Adding support for lwIP (since it is already ported to BBB, this
> >> >>> should not take more time)
> >> >> Timeline seems good. Is the USB support available from freebsd for
> the
> >> >> libbsd codebase?
> >> > Yes. libbsd has support for USB.
> >> > Last year issues were in porting the driver (
> >> > http://gtament-rtems.blogspot.in/2015/06/my-progress-report.html ).
> >> >>> If we have wifi support in RTEMS, can support of a USB wifi module
> be
> >> >>> added to the project?
> >> >> I haven't seen any one using wifi yet.
> >> >>> I'd really appreciate any feedback on my deliverables, especially
> >> >>> regarding the feasibility of doing it in this time frame. If there
> is
> >> >>> anything I may have missed out or anything else I should consider
> as a
> >> >>> part of this, I'd be really glad if someone could point that out, so
> >> >>> as to increase my chances of selection.
> >> >>> A quick question: How can I add my name to the tracking list @
> >> >>> https://devel.rtems.org/wiki/GSoC/2016 ?
> >> >> You need to register an account to edit the page through link at the
> >> >> bottom.
> >> >> Okay, Thank you.
> >> >>> Deval Shah
> >> >>> On Tue, Mar 1, 2016 at 3:07 AM, André Marques
> >> >>> <andre.lousa.marques at gmail.com> wrote:
> >> >>>> Hello Jan and Deval,
> >> >>>> Às 20:24 de 29-02-2016, Jan Sommer escreveu:
> >> >>>>> Hi,
> >> >>>>> If you take a look here:
> https://devel.rtems.org/wiki/GSoC/2015#StudentsSummerofCodeTrackingTable
> you
> >> >>>>> can find the links to the reports and repositories of the previous
> >> >>>>> GSoC.
> >> >>>>> Yurii Shevtsov was doing the work on the Ethernet/USB part for the
> >> >>>>> pi.
> >> >>>>> Andre Marques worked on the SPI and SD-Card driver.
> >> >>>> I have updated a bit the Raspberry Open Projects page with the
> state
> >> >>>> of the
> >> >>>> low level peripherals project, and provided links to the state of
> >> >>>> each of
> >> >>>> the other projects (the wiki pages of the students working on them
> >> >>>> last
> >> >>>> year, which also include their blogs and githubs).
> https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveRaspberryPiBSP
> >> >>>>  The other 3 raspberry projects I do not know exactly their current
> >> >>>> state,
> >> >>>> but they already have some work done (just not in the RTEMS tree
> >> >>>> yet).
> >> >>>> It seems that only GPIO, I2C and SPI were merged last year.
> >> >>>>> Cheers,
> >> >>>>>     Jan
> >> >>>>> Am Tuesday 01 March 2016, 01:15:24 schrieb Deval Shah:
> >> >>>>>> It looks like there are more useful things in pipeline before
> >> >>>>>> raspberry
> >> >>>>>> pi
> >> >>>>>> cam support.
> >> >>>>>> Can anybody give me pointers/links to refer for porting ethernet
> >> >>>>>> support
> >> >>>>>> and SD card support?
> >> >>>> For the last year efforts on the SD card support you can refer to:
> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
> >> >>>>>> On Thursday 18 February 2016, soja-lists at aries.uberspace.de <
> >> >>>>>> soja-lists at aries.uberspace.de> wrote:
> >> >>>>>>> Am 2016-02-18 01:26, schrieb Joel Sherrill:
> >> >>>>>>>> On Feb 17, 2016 6:17 PM, "André Marques"
> >> >>>>>>>> wrote:
> >> >>>>>>>> Was i2c fully delivered for the new driver framework? I don't
> >> >>>>>>>> recall
> >> >>>>>>>>> off-hand.
> >> >>>>>>>>> Yes the i2c driver for the Pi uses the new (linux-based) i2c
> >> >>>>>>>>> framework.
> >> >>>>>>>> 10-bit addressing is untested because I had no compatible slave
> >> >>>>>>>> device.
> >> >>>>>>>>> A detailed report of my last GSOC can be found here:
> >> >>>>>>>>> SD card support was started but not completed last year, so it
> >> >>>>>>>>> may be
> >> >>>>>>>> included on a potential Raspberry project. I can help with that
> >> >>>>>>>> if
> >> >>>>>>>> needed.
> >> >>>>>>>> Andres.. Thanks for speaking up. Can you update the project
> page
> >> >>>>>>>> and
> >> >>>>>>>> link
> >> >>>>>>>> to your blog?
> >> >>>>>>>> What else do you think needs find on the Pi and Pi2?
> >> >>>>>>> Last year there was a GSoC to add ethernet support for the
> >> >>>>>>> raspberry pi
> >> >>>>>>> via rtems-libbsd, but I think it was never finished.
> >> >>>>>>> Maybe that could be started again?
> >> >>>>>>> I haven't researched it yet to know if it is feasible but I am
> >> >>>>>>> curious
> >> >>>>>>> if
> >> >>>>>>>> the Arduino HW libraries have a clean porting layer which could
> >> >>>>>>>> provide
> >> >>>>>>>> support for a lot of i2c devices. Is this a wikd goose chase or
> >> >>>>>>>> of
> >> >>>>>>>> potential value?
> >> >>>>>>> Sounds like an interesting idea, but isn't Arduino written in
> C++?
> >> >>>>>>> Best regards,
> >> >>>>>>>     Jan
> >> >>>>>>>>> I very much look forward for any pointers on this.
> >> >>>>>>>>>>> I am eager to work for RTEMS organization because I believe
> my
> >> >>>>>>>>>>> skill
> >> >>>>>>>>>>> set is best suited for this.
> >> >>>>>>>>>>> Thanking you,
> >> >>>>>>>>>>> Deval Shah
> >> >>>>>>>>>>> _______________________________________________
> >> >>>>>>>>>>> devel mailing list
> >> >>>>>>>>>>> devel at rtems.org
> >> >>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
> >> >>>>>>>>> --André Marques
> >> >>>>>>>>> devel mailing list
> >> >>>>>>>>> devel at rtems.org
> >> >>>>>>>> devel mailing list
> >> >>>>>>>> devel at rtems.org
> >> >>>>>>> devel mailing list
> >> >>>>>>> devel at rtems.org
> >> >>>>> devel mailing list
> >> >>>>> devel at rtems.org
> >> >>>> --André Marques
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160324/4fcfca23/attachment-0002.html>
