GSOC 2016 Aspirant
    Mudit Jain
    muditjain18011995 at gmail.com
    Sat Mar 26 10:17:23 UTC 2016
Hi all,
I had completed the GSoC application successfully and also the basic setup
of the RTEMS environment ready.
A big thanks to everyone who gave me inputs even though it I applied at the
last moment. :)
The link to my proposal is as follows :
https://docs.google.com/document/d/1Ajhs7op7vLUYFeVZnjAaIhB2CNawvhQOMVtGtivOUtg/edit#
Thanks
Mudit Jain
On Fri, Mar 25, 2016 at 9:49 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Mar 25, 2016 at 11:46 AM, Joel Sherrill <joel at rtems.org> wrote:
> > Great! Remember today is the deadline to get the Google application in
> with
> > the PDF of your proposal. Do your best and we will work to fine tune it
> > assuming you meet the Google deadline.
> Not just today, but I think it is in 2.5 hours or so.
> > Please update the table of students (you need a Trac/wiki account to do
> > this) and include a link to your proposal in Google docs.
> This can be completed after Google's deadline, but must be done.
> > The Pi2 should be an interesting project. Last year's student got stuck
> on
> > SMP support. That is important to get working so we have a cheap 4-core
> ARM
> > reference target,
> > --joel
> > On Fri, Mar 25, 2016 at 10:25 AM, Mudit Jain <
> muditjain18011995 at gmail.com>
> > wrote:
> >> PFA patch and a screen shot as a proof of having completed the
> environment
> >> setup.
> >> I have made an initial draft of the application. Will be updating the
> >> google portal and the site soon.
> >> Thanks
> >> Mudit
> >> On Fri, Mar 25, 2016 at 6:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
> >>> OK, that should be a good set for your proposal. I'm not sure what the
> >>> status is for Pi2 now. It may need some cleanup. Make sure you get
> >>> your final PDF and enrollment submitted today.
> >>> Please keep devel on any emails of non-private nature.
> >>> On Fri, Mar 25, 2016 at 8:33 AM, Mudit Jain <
> >>> wrote:
> >>> > Hi Gedare,
> >>> > I have read the link that you have suggested and it has provided me a
> >>> > good
> >>> > insight into the matter.
> >>> > I planned on implementing the support for Pi 2/B
> >>> > In addition to the SD file system support I also plan on adding DMA
> >>> > support
> >>> > for I2C and SPI,
> >>> > support for second SPI device and model identification, detection and
> >>> > reporting.
> >>> > Thanks
> >>> > On Fri, Mar 25, 2016 at 5:23 PM, Gedare Bloom <gedare at rtems.org>
> wrote:
> >>> >> For prior effort on SD card see
> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
> >>> >> There is another student that is planning to add USB/NIC support.
> You
> >>> >> would be best served to avoid too much overlap, but if you go for a
> >>> >> different RPi model that may not matter. What specific RPi board do
> >>> >> you plan to use?
> >>> >> I would guess SD card is only good for the first half of GSoC, so
> >>> >> you'll need to identify what else you could do. The other
> periperhals
> >>> >> (GPIO, i2c, SPI) support have been merged by Andre.
> >>> >> On Fri, Mar 25, 2016 at 6:01 AM, Mudit Jain
> >>> >> <muditjain18011995 at gmail.com>
> >>> >> wrote:
> >>> >> > Hi everyone,
> >>> >> > I am Mudit Jain, a final year undergraduate student in Electronics
> >>> >> > and
> >>> >> > Communication Engineering at BITS Pilani Hyderabad Campus.
> >>> >> > I wish to apply for GSOC 2016, with RTEMS as the mentoring
> >>> >> > organization.
> >>> >> > I have gone through your website for details regarding the
> >>> >> > development
> >>> >> > process and the projects that could be done.
> >>> >> > I am interested in working on the project titled "Low Level
> >>> >> > Peripherals
> >>> >> > and
> >>> >> > SD Card Support for Raspberry PI " [ Project group 1  - Improving
> >>> >> > Raspberry
> >>> >> > PI BSP ] under Alan Cudmore as the mentor.
> >>> >> > Given the limited time I have for the application process, I have
> >>> >> > parallelly
> >>> >> > started to set up the RTEMS environment and also write my proposal
> >>> >> > for
> >>> >> > the
> >>> >> > project that I am interested in.
> >>> >> > I will be updating this email thread once I have set up the env.
> >>> >> > I understand that I am applying at the last moment, however I
> >>> >> > request
> >>> >> > you to
> >>> >> > consider my application.
> >>> >> > It would be great if people could suggest any good points that I
> >>> >> > need to
> >>> >> > account for, in my application.
> >>> >> > Thanks
> >>> >> > Cheers
> >>> >> > Mudit Jain
> >>> >> > _______________________________________________
> >>> >> > devel mailing list
> >>> >> > devel at rtems.org
> >>> >> > http://lists.rtems.org/mailman/listinfo/devel
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160326/b99bd10c/attachment-0002.html>
