GSOC 2016 Aspirant
    Mudit Jain
    muditjain18011995 at gmail.com
    Sun Mar 27 05:17:01 UTC 2016
Hi everyone,
I would be like to fine tune my application.
The link to my proposal is as follows :
https://docs.google.com/document/d/1Ajhs7op7vLUYFeVZnjAaIhB2CNawvhQOMVtGtivOUtg/edit#
It would be great if people could provide me insights/constructive
criticism.
Thanks
Mudit
On Mar 26, 2016 3:47 PM, "Mudit Jain" <muditjain18011995 at gmail.com> wrote:
> Hi all,
> I had completed the GSoC application successfully and also the basic setup
> of the RTEMS environment ready.
> A big thanks to everyone who gave me inputs even though it I applied at
> the last moment. :)
> Thanks
> Mudit Jain
> On Fri, Mar 25, 2016 at 9:49 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Fri, Mar 25, 2016 at 11:46 AM, Joel Sherrill <joel at rtems.org> wrote:
>> > Great! Remember today is the deadline to get the Google application in
>> with
>> > the PDF of your proposal. Do your best and we will work to fine tune it
>> > assuming you meet the Google deadline.
>> Not just today, but I think it is in 2.5 hours or so.
>> > Please update the table of students (you need a Trac/wiki account to do
>> > this) and include a link to your proposal in Google docs.
>> This can be completed after Google's deadline, but must be done.
>> > The Pi2 should be an interesting project. Last year's student got stuck
>> on
>> > SMP support. That is important to get working so we have a cheap 4-core
>> ARM
>> > reference target,
>> > --joel
>> > On Fri, Mar 25, 2016 at 10:25 AM, Mudit Jain <
>> > wrote:
>> >> PFA patch and a screen shot as a proof of having completed the
>> environment
>> >> setup.
>> >> I have made an initial draft of the application. Will be updating the
>> >> google portal and the site soon.
>> >> Thanks
>> >> Mudit
>> >> On Fri, Mar 25, 2016 at 6:16 PM, Gedare Bloom <gedare at rtems.org>
>> wrote:
>> >>> OK, that should be a good set for your proposal. I'm not sure what the
>> >>> status is for Pi2 now. It may need some cleanup. Make sure you get
>> >>> your final PDF and enrollment submitted today.
>> >>> Please keep devel on any emails of non-private nature.
>> >>> On Fri, Mar 25, 2016 at 8:33 AM, Mudit Jain <
>> >>> wrote:
>> >>> > Hi Gedare,
>> >>> > I have read the link that you have suggested and it has provided me
>> a
>> >>> > good
>> >>> > insight into the matter.
>> >>> > I planned on implementing the support for Pi 2/B
>> >>> > In addition to the SD file system support I also plan on adding DMA
>> >>> > support
>> >>> > for I2C and SPI,
>> >>> > support for second SPI device and model identification, detection
>> and
>> >>> > reporting.
>> >>> > Thanks
>> >>> > On Fri, Mar 25, 2016 at 5:23 PM, Gedare Bloom <gedare at rtems.org>
>> wrote:
>> >>> >> For prior effort on SD card see
>> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#SDcardsupport
>> >>> >> There is another student that is planning to add USB/NIC support.
>> You
>> >>> >> would be best served to avoid too much overlap, but if you go for a
>> >>> >> different RPi model that may not matter. What specific RPi board do
>> >>> >> you plan to use?
>> >>> >> I would guess SD card is only good for the first half of GSoC, so
>> >>> >> you'll need to identify what else you could do. The other
>> periperhals
>> >>> >> (GPIO, i2c, SPI) support have been merged by Andre.
>> >>> >> On Fri, Mar 25, 2016 at 6:01 AM, Mudit Jain
>> >>> >> wrote:
>> >>> >> > Hi everyone,
>> >>> >> > I am Mudit Jain, a final year undergraduate student in
>> Electronics
>> >>> >> > and
>> >>> >> > Communication Engineering at BITS Pilani Hyderabad Campus.
>> >>> >> > I wish to apply for GSOC 2016, with RTEMS as the mentoring
>> >>> >> > organization.
>> >>> >> > I have gone through your website for details regarding the
>> >>> >> > development
>> >>> >> > process and the projects that could be done.
>> >>> >> > I am interested in working on the project titled "Low Level
>> >>> >> > Peripherals
>> >>> >> > and
>> >>> >> > SD Card Support for Raspberry PI " [ Project group 1  - Improving
>> >>> >> > Raspberry
>> >>> >> > PI BSP ] under Alan Cudmore as the mentor.
>> >>> >> > Given the limited time I have for the application process, I have
>> >>> >> > parallelly
>> >>> >> > started to set up the RTEMS environment and also write my
>> proposal
>> >>> >> > for
>> >>> >> > the
>> >>> >> > project that I am interested in.
>> >>> >> > I will be updating this email thread once I have set up the env.
>> >>> >> > I understand that I am applying at the last moment, however I
>> >>> >> > request
>> >>> >> > you to
>> >>> >> > consider my application.
>> >>> >> > It would be great if people could suggest any good points that I
>> >>> >> > need to
>> >>> >> > account for, in my application.
>> >>> >> > Thanks
>> >>> >> > Cheers
>> >>> >> > Mudit Jain
>> >>> >> > _______________________________________________
>> >>> >> > devel mailing list
>> >>> >> > devel at rtems.org
>> >>> >> > http://lists.rtems.org/mailman/listinfo/devel
>> >> devel mailing list
>> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160327/fe7d7c80/attachment-0002.html>
